Front cv joint/ differential problem
Old Feb 29, 2008 | 12:14 PM
86 yota's Avatar
I recently installed the bj spacer on my truck and discovered in the process that i some how pulled the side gear shaft out of the tube about an inch and a half. What i need to know is do i just slide this back in place or did i break something that held the cv joint flange inside of the tube. I can add pictures if some needs to know what i am talking about. Thanks
Old Feb 29, 2008 | 12:41 PM
RustBucket's Avatar
It is held in place with a c-clip near the end of the half-shaft. You should be able to carefully tap it back in. If it gives you alot of resistance, you might need a new c-clip (like $0.90 from Toyota)
Old Feb 29, 2008 | 02:25 PM
86 yota's Avatar
so if we are able to tap it in then dont worry about it or take the diff cover off and replace the c clip. Also is it fine to drive like this and without the c clip. I have man locking hubs so it should be alright.
Old Feb 29, 2008 | 02:59 PM
86 yota's Avatar
Ok so me and my dad just spent 20 min trying to beat the shaft back in and to no avail so anyone have any other suggestions as to what it may take to get this thing back into its seat? I still cannot figure out how i pulled this thing out. and now it will not go back in
Old Feb 29, 2008 | 06:19 PM
gte718p's Avatar
Pop the pumpkin. Take it all the way out make sure everything is straight and there are no burrs or ridges on the shaft. Reassemble. Its not a long or involved job.
Old Mar 5, 2008 | 03:36 AM
86 yota's Avatar
OK so i still have not gotten the half shaft back into the tube. I am really aggravated at this point. Have i messed something up by unknowingly placing my truck into 4wd without knowing the shaft had come out. Also if i pull the differential cover off what am i looking for. Is the Detroit truetrac making this difficult to line up or have i messed something up already and thats why it has not gone back in. If anyone has any personal experience with this please either comment or PM me. I am very close to having to take this thing to a shop which i do not want to do so any help would be greatly appreciated. Thanks, Clint
Old Mar 5, 2008 | 12:03 PM
86 yota's Avatar
Srry that i keep interupting but i am hoping someone who knows what they are doing and will see this post and help out.
Old Mar 5, 2008 | 12:13 PM
Justinvd's Avatar
I think i know what your saying. Do you have any pics handy?
Old Mar 5, 2008 | 01:15 PM
86 yota's Avatar
Here are some pictures of what i am talking about.
http://i228.photobucket.com/albums/e...8/100_0978.jpg
http://i228.photobucket.com/albums/e...8/100_0977.jpg
http://i228.photobucket.com/albums/e...8/100_0976.jpg
http://i228.photobucket.com/albums/e...8/100_0975.jpg
http://i228.photobucket.com/albums/e...8/100_0974.jpg
Old Mar 5, 2008 | 01:50 PM
jason191918's Avatar
Does this help any?
http://personal.utulsa.edu/~nathan-b...18frontdri.pdf
Old Mar 6, 2008 | 03:45 AM
86 yota's Avatar
No that is just the cv joints. I need info on the actual axle that slides into the long side of the axle housing. If you look in my pictures above you can see what has pulled out.
Old Mar 6, 2008 | 08:16 AM
GSGALLANT's Avatar
That looks like a non-ADD setup you have there. If that's the case, the info you need is here.. However, it's already been posted above. There is a snap ring that helps hold the side gear shaft in. Remove the side gear shaft completely, and inspect the snap ring and the splines on the shaft. If everything is in good shape, slide it back in, making sure the splines line up (by feel) When all is lined up, you should be able to tap the shaft back into place.
Old Mar 6, 2008 | 10:16 AM
ozzydg55's Avatar
take it apart and reassemble with new snap rings
lledwod
Aug 30, 2016 01:03 PM
shisha1999
Mar 16, 2016 12:25 PM
jerusry
Oct 19, 2015 05:28 PM
AaronM
Jul 8, 2015 07:15 PM
