Codes 21 & 43
Old Mar 4, 2008 | 10:29 AM
CW's Avatar
CW
Codes 21 & 43
My check engine light came on for the first time since i got my 90 4runner the other day. 21 & 43 came up. Is it normal to set these at the same time?
21 is o2 sensor and 43 has me baffled its starter signal.
The light came on after i had been driving it all day and i was on the hiway when it came on.
I did do a compression test with the coil wire off, would that possibly set the 43 code? I hadn't checked the codes before i did the test.
Old Mar 4, 2008 | 10:36 AM
Albert.G's Avatar
try taking your efi fuse out for 10 minz, or disconnect the battery, sometimes it takes the codes away
moparbay
Oct 6, 2015 09:24 AM
bradahman
Oct 1, 2015 09:24 AM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
Draven023
Sep 26, 2015 12:41 PM
