newb timing chain questions
Old Mar 5, 2008 | 08:07 PM
scuba's Avatar
Talking newb timing chain questions
im a newb at all this mech stuff
i have a 91 22re
im pretty sure i have a blown head gasket
due to a water pump leak leading to an overheat
DOH
well
after draining my coolant for a water pump change (prolly the most mechanical thing ive done)
and having my coolant come out looking like this
im almost certain i have a blown head gasket
I also get white smoke on startup
with the FSM i found online, help from a pretty mechanically inclined friend, and of course the experts on here im pretty sure i could do it.
END CHAPTER 1.
CH 2
my question is
does anyone have any concerns with the lce engineering double row TC ??
i figured while i had the darn motor apart i should prolly change it (115k and no clue if it has been changed before?!)
i was gonna purchase it as well as the engnbldr gasket set
and also hopfully a camshaft
any comments or concerns i should know about before i head into this venture ??
Old Mar 5, 2008 | 08:21 PM
toytech76's Avatar
Are your tchain guides broken? If so, make sure they didnt saw through your tcover. There is a coolant passage right behind where the drivers side guide is and it can chew through it and dump coolant into your eng
Old Mar 5, 2008 | 08:27 PM
scuba's Avatar
honestly i havent checked
ive only had the truck for about 4 months
i figure its the head gasket
should i just start with changing the chain and guides instead of the head gasket itself ??
Old Mar 5, 2008 | 08:30 PM
toytech76's Avatar
you can pull the valve cover and look down at the drivers tchain guide to see if its broken. If it is, you might want to find someone who can pressure test the cooling sys to check for leaks
Old Mar 5, 2008 | 08:36 PM
91Toyota's Avatar
just change the head gasket too. It will be much easier...but still a big pita though
Old Mar 5, 2008 | 08:43 PM
toytech76's Avatar
well the idea is to NOT just throw parts at something hoping you will fix a problem when you dont know exactly what it is. Thats the wrong way to go about things. If you ran a shop, you certainly wouldnt have much of a customer base doing that
Old Mar 5, 2008 | 08:49 PM
scuba's Avatar
ha
lol
if only exactly i knew what the valve cover was
is that the very top of the motor??
Old Mar 5, 2008 | 08:55 PM
toytech76's Avatar
yes. it has a plate with vac lines and switches on it. The V/C has 4 nuts with rubber grommets holding it down
Old Mar 5, 2008 | 08:58 PM
scuba's Avatar
so take it off
look at the timing chain guides ??
if all seems well what would step 2 in your mind be ??
Old Mar 5, 2008 | 09:00 PM
toytech76's Avatar
when pressure testing your cooling sys...pull your spark plugs out and check the cyls for coolant. If its present..pull the head
Old Mar 5, 2008 | 09:07 PM
scuba's Avatar
sorry for all the questions
but how would i pressure test ??
and your saying pull the spark plugs and if i see coolant in those holes i need to change my HG ?
Old Mar 5, 2008 | 09:08 PM
toytech76's Avatar
You need to get a cooling sys pressure tester. It fits on your radiator and you pump it up. You could also have a cracked/eroded head as well so, if there is coolant in there then you need to pull the head and have a machine shop inspect it
Old Mar 5, 2008 | 09:14 PM
scuba's Avatar
hmmm
intresting
honestly if thats the case
and this motor is more fudged then i think
i have a spare 22re from a wrecked 86 one ton
would there be much trouble swaping ??
Old Mar 5, 2008 | 09:44 PM
scuba's Avatar
dang
toytech got off
anyone else have any opinions ??
Old Mar 5, 2008 | 09:51 PM
Matt16's Avatar
Back to the timing chain, I'd just replace it with the factory setup. Then I'd forget about it for a couple years and then change it again. Sure you could spend some cash on a more bullet proof 22RE but its not like they were unreliable from the start.
Old Mar 5, 2008 | 09:59 PM
scuba's Avatar
see thats the thing
i wouldnt have to spend cash on a new one
i have an 80k one in a wrecked 86
i was just wondering if this motor is more jacked then i thought
if it would be possible to swap that one in
and how hard it would be
Old Mar 5, 2008 | 10:25 PM
Matt16's Avatar
Pretty easy I would think. They're really simple motors. I think it wouldn't me much more work than removing the exhaust manifold, radiator, undoing the bellhousing and the motor mounts. Then disconnect and label the fuel and vacuum lines and some wires. You'd have to flesh it out a bit, but you get the idea. You luckily have a tonne of room to work in once the rad and exhaust manifold are out. It might be a bit tight on the passengers side, but doable.
My guess it would take you a weekend to unbolt everything then a weekend to drop in a new motor.
Anyone done this that would be able to confirm/ deny/ flesh out this plan?
Old Mar 6, 2008 | 12:44 PM
mountaingoat's Avatar
You could just put the other 22re in, sure - but what if your timing chain guides go on the new used motor in 20k miles? You'd feel a little dumb I bet.
I'd suggest going ahead and doing the head gasket and the timing chain/guides/etc. Once you've got the head off to do the gasket, then doing the timing components isn't that much more work or expense, and then you'll know you've got good parts in there.
If you'd just rather swap in the used motor with 80k on it, sure go ahead - but check the timing guides on new motor and replace them if needed BEFORE you swap out the motor, it's much easier that way. Then you'll know that the new motor you're swapping in is as good as it can be...
Old Mar 6, 2008 | 06:59 PM
scuba's Avatar
would there be any issues with the wiring harness or anything ??
Old Mar 6, 2008 | 08:59 PM
scuba's Avatar
anyone have any insight ??
bigjstang
Jun 2, 2025 03:56 PM
Avenged
Jul 9, 2015 07:55 AM
Cplmike
Jul 8, 2015 08:47 PM
