Best flowing head for a 22r-e
Old Feb 28, 2008 | 12:47 PM
mr_schuster's Avatar
So I already have a TRD cam in my factory 22R-E motor and it works great, but I am seeking more power. I read posts by different people suggesting that Engnbldr, LCEngineering and D.O.A. make the best performance heads. Can anyone make a suggestion on which company to purchase from.
I was also considering the adjusting the air flow meter a few teeth. Would this make any difference in perfromance? I am utilizing the factory air cleaner, a TRD cam ( the small one) and have an exhaust system from a V6 4Runner (cat back).
Thanks in advance.
Old Feb 28, 2008 | 12:49 PM
04 Rocko Taco's Avatar
TRy a 20R, i know they do wonders for the 22R, I bleive they will fit on a 22RE also.
Old Feb 29, 2008 | 04:27 AM
dcg9381's Avatar
In terms of performance, you're wanting to match head flow (in CFM) to the right camshaft. LC advertises stage 1 - stage 5 heads in various CFM. Tim @ DOA has a ton of experience porting 22R series heads - he matches them to cams and will provide flow results. Tim did my head.
Engnbldr's son does head porting. I've heard good things and I really like Engnbldr, but I've never purchased a ported head from him or his son.
Adjusting the AFM adjusts your mixture across the board. I wouldn't suggest adjusting it unless you've done enough mods to justify the mixture change. The difference will be very small in most cases. If you do it, make sure you mark the original position.
Old Feb 29, 2008 | 07:47 AM
RustBucket's Avatar
My guess is that if you go with Engnbldr you'll end up paying the least... I know you can buy his "street RV" head sans cam for less than $500 and his cams are like $88 after that.
Old Feb 29, 2008 | 12:59 PM
jmazoso's Avatar
I bought and RV head and a 261 cam from Tim. I am very happy with it, and they are great to work with. It's probably overkill right now, but I am planning to put on a Weber 38, headers, and a multi-spark coil.
Old Feb 29, 2008 | 01:07 PM
dcg9381's Avatar
FYI:
TED=engnbldr
TIM=DOARacing
RatOmeter
Oct 22, 2015 03:17 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
wwjr
Sep 7, 2015 09:27 AM
JAmdor3
Aug 11, 2015 10:53 AM
jjrbus
Jul 17, 2015 07:06 AM
