just bough a 95 4runner...have some ?
Old Feb 24, 2008 | 08:28 AM
surfer5567's Avatar
so yesturday i picked up a ridiculously clean 95 4runner 4x4 5spd with 135k on the 22re. i was wondering if you guys could maybe throw some links my way to answer my questions.
how do i figure out what trans and transfer case i have?
are there any "free" mods i can do to wake the 22re up a bit? i know i need new plugs as they are pretty white. i know that means lean, is that really bad or could it be because they are old?
most importantly, when im was cruising around last night in the rain, i had my AC and defroster on as the windows where getting pretty bad and when i wouuld come to stop and the rpm's would drop, everything would die for a moment and come back on. when i would turn the AC off, this didnt happen. is this normal? what does this mean? anything i can do to fix this?
also, where can i get the kit to take away the clunk that happens when you crank the wheel to the left all the way?
thanks for all the help!!!
Old Feb 24, 2008 | 08:31 AM
Elton's Avatar
welcome aboard great choice goin with the 22re as for free mods theres really not much tell u start spending money on a cam a header and a full exhaust
Old Feb 24, 2008 | 08:34 AM
bigt's Avatar
maybe your battery or alt is on its way out.... with the ac/ head lights and defog on your are u sing alot of juice..... the sticker in your door jam should point you in the direction of the info you seek... i have 2 4runners like yours and would like to know the tranny and transfercase we have.. i know i have 4.10 gears
Old Feb 24, 2008 | 08:38 AM
4Mogger's Avatar
Cap, rotor, plugs (correct plugs) and wires (all Toyota Genuine Parts) and air filter, fresh oil and then you will have a baseline to see what you are starting with. If the engine oil is really nasty (look for discoloration on the dipstick for clues) then an oil additive and drive a few miles and change the oil again. I also do this with with my radiator every summer. Drain and fill with distilled water and redline water wetter and drive for a month or so before draining and filling with the correct Toyota Factory (red) coolant. Just be sure to pull the top hose off and fill the block passages to prevent air pockets from forming in the system.
Old Feb 24, 2008 | 06:48 PM
surfer5567's Avatar
what is the bolt pattern for the rims on this truck as well? i am goin to have the charging system checked this week. i just bought some injector cleaner and some new spark plugs tonight. i am planning to go up to the snow this weekend. is there anything i should be aware of while going up or should it be ok?
also i think i found a supercharger(trd) for the 22re. is it true toyota makes one? how well does it work on the 22re?
again, thanks for the help!
Old Feb 25, 2008 | 02:51 AM
nix4x4's Avatar
Surfer...
To answer your drivetrain questions,
your 4Runner is equipped with the W56 transmission
and RF1A transfer case.
You might wanna spend some time on
http://www.4x4wire.com/
They've got a section dedicated to Toyota 4WD
and it was a big help in gaining a basic knowledge
of these little beasts when I was first getting into them.
As far as engine mods go, nothings free, my friend.
However, a good cat-back, some intake modifications,
and a mild cam if you're feeling adventerous will
get the hamsters running a little stronger, but the fact remains
that, as dependable as the 22RE is, it will never be a powerhouse.
With 135k on the ticker, regular tune-ups and proper maintanece (sp?)
should give your 4Runner a long life without many issues.
Old Feb 26, 2008 | 07:30 PM
surfer5567's Avatar
thank you that was super helpful!! i will check out 4x4wire for sure. so i think i narrowed down the problem with my truck dieing for a few seconds. when i turn my AC on the lights dim and the engine bogs. why could this be? is my ac compressor going out or is my altinator going out? somethings not right and im trying to narrow it down to what it could be. the battery has a full charge.
Originally Posted by nix4x4
Surfer...
Old Feb 26, 2008 | 08:22 PM
DeathCougar's Avatar
Surfer...
Eh, no. 99.9% of 4Runners came equipped with ADD, whether or not it was 4cyl or V6. And since it has ADD, it also has a G58 trans and a Chain drive transfer case.
Old Feb 26, 2008 | 08:26 PM
scuba's Avatar
one good thing to do is replace your alternator brushes
pm
https://www.yotatech.com/members/30002.html
this guy
brushes shiped to you for like 15 bucks
Old Feb 27, 2008 | 11:45 AM
surfer5567's Avatar
pm
this guy
what would these brushes do? would anyone suggest getting my charging system tested to see if thats the problem?
Old Feb 27, 2008 | 12:00 PM
89whitetoyota's Avatar
From: Cincinnati, Ohio - Amelia is the exact place. There is no one else on this site from where I am. Seems like everyone is from Cali or Washington. I guess I need to move.
Your battery should be around 14-16 at full charge, if it reads 12 your alternator is probably struggling. When I turn my fog lights on with the heater my rpms take a dip. I would get a high amp output alt that way later down the road you can run lights and other aux stuff with out draggin the motor down.
Old Feb 27, 2008 | 12:23 PM
anthony1's Avatar
For the AC on, engine dying problem, I think the problem is the idle doesn't change. It's suppose to increase the idle when you turn on the AC. As far as solution, I don't know.
maybe TPS?
Old Feb 29, 2008 | 01:31 PM
surfer5567's Avatar
maybe TPS?
do i changed the plugs(without gapping) and ran some injector cleaner through it and the problem got worse. i gapped the plugs to .031 and the problem is still there. idels around 250rpm and dies 80% of the time. runs fine once im moving, just wont idel. any idea what else it could be?
RallyFreak77
Apr 16, 2014 11:03 AM
toyland99
Mar 29, 2014 05:07 PM
Nick91runner
Jan 9, 2014 07:17 PM
Dustysmac
Feb 18, 2012 07:18 AM
89Pick-Up
Feb 15, 2010 04:35 PM
