efi swap any help
Old Mar 4, 2008 | 03:17 PM
mudtoy1986's Avatar
efi swap any help
hey i own a 1986 toy p/u and it has a 22r i jus purchased the entire rear cab section of an 89 4runner in order to be able to use the rear window and wiper opts i decided to pull the entire under dash harness but found out its going to be much more work than i planed so i pulled the rest of the efi harness from under the hood ok heres where my question comes into play i snaged an intak and exaust off the 86 runner will the efi intake work on the carbed head i know i need the block off plate and i have to get the fuel tank as well i have read on other sites that i will need to change the lines do i have to change them from the tank to the motor or can i just change the rubber flex lines any help at all ?
ok the parts i have for a little beter reading since my gramer sucks
86 toy p/u with 22r
rear cab assembaly from an 89 4runner to be atached at the rear of the p/u
compleate intake 22re 86 runner
exaust manifold 86 runner
entire wire harness from fire wall to tail gate (did not cut anything)
entire engine harness
will be getting sensors from the trans and block
will be getting efi fuel tank
please any help as to what else i need it would be greatly apriciated
or to keep me from doin as much work any one have a harness from a carbed 4runner either 85 or 86 will work perfectly thanks for any help
RobotMoose
Diesel Swaps
Aug 2, 2015 11:00 PM
toofly1999
Jul 25, 2015 07:09 PM
GeoRoss
Jul 24, 2015 03:03 PM
Sandman
Jul 14, 2015 12:36 PM
dpridgeon3
Jul 9, 2015 01:18 PM
