I got one for ya....(95 T4R)
Old Feb 28, 2008 | 09:18 PM
drew415's Avatar
When driving on the freeway, the temperature gauge on my 95 4runner travels wildly back and forth. Only on the freeway, not in town. It goes to cold, then back to the middle and vise versa. Loose connection somewhere?? Any help much obliged!
Old Feb 28, 2008 | 09:23 PM
stormin94's Avatar
hey, mine does that too!!!
Mine goes from mid, to cold, real quick like, esp when I give it gas. Not so much when I let off. I'm guessing it's a loose connection,or a bad temp sensor.
Old Feb 28, 2008 | 09:33 PM
drew415's Avatar
Hmmmm.... I'm glad i'm not the only one! Thanks for the reply! Do you know where the temp sensor is??
Old Mar 2, 2008 | 07:23 PM
drew415's Avatar
Anyone else have this happen?? Anyone know how to fix it?? Thanks all!
Old Mar 3, 2008 | 05:55 AM
mtrdrms's Avatar
Check the coolant level first. If thats not it then I would go with a bad temp sender. The sensor gives info to the computer and helps regulate mixture and eng speed. the sender gives a signal to the guage about engine temp. Check that connection or replace it.
Andy
Old Mar 7, 2008 | 06:36 PM
drew415's Avatar
Thanks mtrdrms. Coolant checked fine. I just need to know the location of the sensor so I can check it. Anyone know?? Thanks!
Old Mar 7, 2008 | 06:48 PM
Targetnut's Avatar
The temp sensor is on a small housing that is bolted to the back of the intake manifold. Besides low coolant level two other things that could contribute to these symptoms are a faulty connection in a ground splice in the harness in the engine compartment. Somewhere ther is a technical bulletin about this.
also the little hose that is connected to the sensor housing can get plugged up
Old Mar 7, 2008 | 06:53 PM
CoedNaked's Avatar
You're gonna have to do a 3.4 swap to correct this issue unfortunately.
Jun 1, 2021 01:51 PM
JamesDINAN
Sep 22, 2015 05:37 AM
Boomer8404
Sep 17, 2015 07:59 AM
rchavis
Jul 27, 2015 07:41 AM
layifioren
10
Jul 6, 2015 02:26 PM
