auto shifter
Old Mar 5, 2008 | 10:52 AM
huntnfreak's Avatar
auto shifter
I was wanting to know if there was any way that you can remove the gear shifter handle and the auto 4x4 shifter handle for a aftermarket one.
Old Mar 5, 2008 | 11:11 AM
mt_goat's Avatar
Not really, there is the OD on/off button in the main shifter, plus there is the little lock mechanism. It is a fairly complex little device. I couldn't even figure out how to take it apart when I was looking at it so good luck with that.
Old Mar 5, 2008 | 11:17 AM
huntnfreak's Avatar
thanks man i guess i will just leave it be
Old Mar 5, 2008 | 11:18 AM
huntnfreak's Avatar
what about the 4x4 shift handle
Old Mar 5, 2008 | 11:22 AM
mt_goat's Avatar
It's a lot more simple, you probably could swap that one. Been a while since I looked at it though.
Old Mar 5, 2008 | 11:29 AM
huntnfreak's Avatar
any ideas where i can find one
Old Mar 5, 2008 | 11:32 AM
mt_goat's Avatar
Nope, I don't see anything wrong with the factory one myself.
Old Mar 5, 2008 | 01:59 PM
4rnr's Avatar
there are no aftermarket ones, that I know of. there is a lock button in the top of the handle....
why do you want to replace it??
Old Mar 5, 2008 | 05:01 PM
Dublin's Avatar
Replaced mine with a 2wd 4Runner shifter just because I liked the look and feel and because I could. A bit of a pain to install though, had to cut the OD wiring, solder and heat shrink the splice, and drill new attachment holes.
I think the LandCruiser shifter would work too, a bit larger though.
Old Mar 5, 2008 | 05:38 PM
huntnfreak's Avatar
i was just woundering if it was possiable thanks guys for your info.
I will keep the factory shifter
Hugh_Mann
Sep 16, 2015 03:59 AM
potatopants
Sep 15, 2015 06:26 AM
May-39
Sep 6, 2015 01:05 PM
eggens
Sep 5, 2015 12:16 AM
