land cruiser coils ????
Old Mar 5, 2008 | 05:19 PM
4runnerguy's Avatar
ok i have a question a what year and what coils do i need is it from the front or rear of a landcruiser
Old Mar 5, 2008 | 05:30 PM
4runnerguy's Avatar
bummmmmmpppppppp
Old Mar 5, 2008 | 06:17 PM
WCorbett's Avatar
you need rear coil spring from a 96 or 97 or that gerneration land cruiser.
Old Mar 5, 2008 | 06:28 PM
Hallz97SR5's Avatar
Hey I found this link a couple of days ago.
FZJ80 Springs on 4Runner/
There is a lot of info, and a lot of posts. Its like 15 pages all about what your talking about.
Im planning on doin the same lift. And its the front Land Cruiser Coils that you use, and its like 91-97 or 93-97. I dont remember, but its in there!
Old Mar 5, 2008 | 06:29 PM
Hallz97SR5's Avatar
Err,
What year do you have? 3rd Gens use the Land Cruiser Front Coils, but 2nd Gens im not sure?
You have a third gen? Cuz then the post is correct, if not, then I have no idea lol
Old Mar 5, 2008 | 06:53 PM
WCorbett's Avatar
thrid gen runner wants front cuiser coils from same generation. second gen runner wants rear coils.
Old Mar 7, 2008 | 09:10 AM
4runnerguy's Avatar
i have a 2nd gen 1991 toyota 4runner
Old Mar 7, 2008 | 09:37 AM
YeloSub7's Avatar
ya you want the rears off an FZJ80 91-97
Old Mar 7, 2008 | 09:55 AM
4Hummer's Avatar
Yup.
Careful they are super flexy. Not something I'd recommend on a Daily Driver.
Or at least learn to Drive slow, not change lanes fast, slow down on On/off ramps
Off Road however SWEEET. See Pics (And I Cut 3" inches out of the rear fenders)
Almost Full Stuff
Fully extended
You will need longer Brake Lines, Ditch the LSVP in the rear, and longer shocks. Plus something to lift the front SDORI Ball Joint spacers, with Major T-Bar Crank And I still have Rake
Old Mar 7, 2008 | 11:05 AM
4runnerguy's Avatar
thats sweet thats what i wanna do
Old Mar 7, 2008 | 11:40 AM
904_runner's Avatar
I plan on doing that too! What do you mean by ditch the LSVP? Also, do you have to modify the spring seats? Thanks
Old Mar 7, 2008 | 12:53 PM
4Hummer's Avatar
You need to remove the LSPV (Load sense prop valve) Its attached to the rear axle and detects when you have weight in the rear (IE carring a load) and applies more brake pressure to the rear drum. DITCH it and add a manual prop valve to the front master. or you will have no rear brake pressure,
Heres a pic
Add one of these instead
edit some people have added a bracket lifting the prop valve up the same height as the Lift (I had no luck and very spongie brake pedal)
No modification required to fit the coils (They drop right in) You will need longer shocks and a
a drop bracket or lift bracket for the rear pan hard bar.
Old Mar 7, 2008 | 01:02 PM
904_runner's Avatar
How hard is it to replace the LSPV (Load sense prop valve)
Old Mar 7, 2008 | 01:05 PM
904_runner's Avatar
also where would you get one!
Old Mar 7, 2008 | 01:10 PM
4Hummer's Avatar
Ill take pics tonight. Pretty easy. You get the manual Prop Valve from Summit.
http://store.summitracing.com/egnsea...918719&NeXID=5
Theres a write up somewhere on the next 4x4wire maybe?
Old Mar 7, 2008 | 05:17 PM
4runnerguy's Avatar
hey 4hummer were in canada u live
Old Mar 7, 2008 | 05:35 PM
4runnerguy's Avatar
does eny one know were in canada ontario i can get land cruiser coils
Old Mar 8, 2008 | 10:10 AM
904_runner's Avatar
Yea, im struggling to find some too! I can get the rear coils off a fj80 for a $100. Sound right? or should i just pay $40 more and buy new ome ones? Thanks,
Old Mar 8, 2008 | 01:25 PM
bry-an's Avatar
that sounds pretty reasonable... be clear if you have a 95.5 or newer you need the fronts(they are narrower) and if you have a 2nd gen like me, you need the rears. I made that mistake it sucked .
if you buy the ome ones make sure they arent lift coils for the fj or you will have more like a 6 inch lift instead of a 3-4 inch lift.
Old Mar 8, 2008 | 07:27 PM
904_runner's Avatar
Okay good advice. Its a 1990 4runner that i have. I already ordered a front 4" lift by trailmaster used from some wrecking yard. So next paycheck i will order some coils i think its off a 94 but im not too sure, and the panhard drop bracket or whatever that is called, and remount that LSPV or buy a different one. ANd longer shocks.
Thanks for the help!
