4x4 noises
Old Mar 6, 2008 | 03:20 PM
jsn_stockard's Avatar
4x4 noises
My truck just started making a nice growling noise from the right front. It only does it when the hubs are locked in. If I shift from 2 to 4wd it stops for a bit. It does do it both in 4 and 2wd. Any ideas? Wheel bearings were just greased a few months back. 92 4x4 ifs
Old Mar 6, 2008 | 07:15 PM
hkspwrsche's Avatar
bearings can go bad. Did you grease them becuse they were noisey?
Old Mar 7, 2008 | 03:20 AM
TORTIS's Avatar
it could be the cv shaft rubbing inside the front hub. i would think that if it were the front bearings, it would do it all the time. might be the front diff bearing.
Old Mar 7, 2008 | 06:20 AM
I grease them every 6 months or more, more if I do deep water crossings. What would be causing the joint to start rubbing
mskalmus
May 28, 2017 07:51 AM
coleypull15
Nov 3, 2015 07:41 AM
PlayAwhile
Jul 20, 2015 11:36 AM
razorman8669
Jul 12, 2015 12:13 PM
Jonny246
Jul 12, 2015 04:51 AM
