Starter on 5VZ-FE
Old Jun 23, 2007 | 10:26 AM
boardstar's Avatar
Starter on 5VZ-FE
mine just went ... heard from a friend with a 4runner (3vz-fe) that he needed to unbolt some motor mounts and lift the engine to get the starter out.
Can anyone confirm this is the same for the 5z engines?
or can i squeeze the damn thing out through somewhere..?
thanks
Old Jun 23, 2007 | 10:33 AM
Knuckles's Avatar
Just take off the Skid Plate.
Old Jun 23, 2007 | 10:57 AM
Bigblock's Avatar
Most will squeeze thru.
Old Jun 23, 2007 | 01:39 PM
TRDatVT's Avatar
With a universal joint/wobble extension and some persistence, it took me about 25 minutes to change out mine. Should be very simple.
Old Jun 24, 2007 | 06:22 PM
breknraj's Avatar
Tell your friend with the 3V to make his life easier next time - use the access panel in the passenger side wheel well.
And no, the FSM doesn't even mention it!
Old Jun 24, 2007 | 06:29 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
there was no access panel for me. with about an hour of wrenching awkwardly, i was able to unbolt my starter. i put my tetris skills to use and was able to twist it around in such a way that i could slide it out through the wheel well and do the reverse to put it back in. i could have gotten it from underneath if i could have remove the piece of metal behind it, but the bolts are rusted solid.
ladybugRC
458
Aug 21, 2020 10:41 AM
pickle6415
Oct 19, 2015 08:08 AM
zombie_barbarossa
Oct 2, 2015 10:54 PM
bradahman
Oct 1, 2015 09:24 AM
beltcutter
Sep 30, 2015 06:14 AM
