3.0 timing
Old Jun 29, 2007 | 10:28 AM
4_runnin's Avatar
3.0 timing
ok all the marks line up im around 12 to 10 btdc (good) but when i start out it just boggs down bad feels like im running one 1 cylinder im clue less at this point checked vacuums what in the world could be causing this ive never had so much trouble with timing in my life
Old Jun 29, 2007 | 11:11 AM
eric-the-red's Avatar
Did you jumper the pins in the diagnostic connector, TE1 and E1 iirc. When I drove my 2nd gen I could never get the timing right either. I ended up doing it by ear and seat of the pants. I just advanced mine until it pinged and backed off a bit.
Since I switched to the 3rd gen I've never had problems, of course that could be because they don't have a distributor.
Old Jun 29, 2007 | 12:57 PM
jblake00's Avatar
Have you tried a compression check? I thought I had a timing issue for months, but it ended up being a burnt valve in my passenger head.
Old Jun 29, 2007 | 01:11 PM
4_runnin's Avatar
if i gotta burnt valve somebody is gonna get an ear full i just paid 1200 bucks for a complete rebuild on the block new pistons the works and a complete head job
Old Jun 29, 2007 | 01:13 PM
4_runnin's Avatar
yeah eric ive done it with the jumper and without about 50 times thanks though
Old Jun 29, 2007 | 01:29 PM
4_runnin's Avatar
ok all the marks line up under the timing light ........... from a dead stop floored it just doesnt want to move wth anything people im all ears
Old Jun 29, 2007 | 02:04 PM
4_runnin's Avatar
and yeah eric the no distributor thing could be it but that just gets more in the ecm controlling issues i have .......ok here goes im not a really big fan of the ecm these days ........dont get me wrong they do make things better (its kinda like making something perfect) but when one little sensor goes bad the whole entire system goes hay wire and the prices for these little things dont get me started on that
Old Jun 29, 2007 | 03:05 PM
MudHippy's Avatar
Mine did like that when I had my vac lines crossed up. Switched up, whatever you wanna call it. Both plugged in where the other should be. Took me a few days to catch it, 'bout drove me crazy(short trip).
Old Jun 29, 2007 | 04:34 PM
4_runnin's Avatar
lol if this is just a vac line there must be one in the middle of the engine one have never seen thats connected to the crank qand the first piston
Old Jun 29, 2007 | 04:35 PM
4_runnin's Avatar
its a program in teh computer ive known this for a while
Old Jun 29, 2007 | 05:42 PM
Ganoid's Avatar
Is this something that just randomly started happening or did you just finish some work on it? Your statement about rebuilt block,pistons and heads leads me to believe that maybe you just finished assembly ?
Old Jun 29, 2007 | 05:44 PM
MudHippy's Avatar
So you said you know you have a bad O2 sensor, have by-passed the BVSV, and have gotten a code for the knock sensor (52 or 53?). If it's 53, faulty knock control program, I don't see it reprogramming itself(but what do I know?).
Try an O2 sensor. I haven't heard how you can do without one of those. I thought they were fairly crucial for the ECM to do it's job.
Old Jun 29, 2007 | 06:37 PM
4_runnin's Avatar
na code 52
and the o2 sensor is kinda crucial but i dont see how it could e doingthis
Old Jun 29, 2007 | 06:39 PM
4_runnin's Avatar
ganoid im curious about the custom weilded intake manifold you got tell me more pics to if you got em
Old Jun 29, 2007 | 07:05 PM
Ganoid's Avatar
Its an old post have a look.
http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
Old Jun 29, 2007 | 09:13 PM
4_runnin's Avatar
3.0 intake mods
does anyone know of a intake for the 3.0 that doesnt cover up the whole dang left side of the motor
Old Jun 30, 2007 | 12:19 PM
4_runnin's Avatar
im guessing this is going to sound silly but wth does top dead center mean the 1st piston is all the way up or all the way down i get it to be all the way up hence the word top but ill go with anything at this point
Old Jun 30, 2007 | 02:07 PM
isaac338's Avatar
tdc means the piston is at the very top of its travel, immediately before beginning to move downwards.
Old Jun 30, 2007 | 02:25 PM
MudHippy's Avatar
Nice!
Old Jun 30, 2007 | 04:13 PM
4_runnin's Avatar
lmfao ok here goes this dang rebuild has had my mind going crazy but i finally got it ......the timing issue.. i was on the exaust stroke , believe it or not fliped it 360*.so its purring the 10* btdc i finally figured its not going be the same since im bored of 50 and crank work, and bearing over size, rod work....putting this together the first time i figured all that but had to tear in it afew times after the first put together .
