Speedo/PRNDL light not working
Old Jun 23, 2007 | 07:28 AM
dbwan's Avatar
My dads truck (92 pickup 22RE w/ auto tran electronic speed sensor) speedo and gear selection lights aren't working at all. I thought it was the cluster so i changed that and its not the problem. Has anyone run into this problem? I tried searching but there were no result for this problem. Thanks in Advance
Old Jun 23, 2007 | 08:29 AM
eightnine's Avatar
my truck has the exact same problem as the lights of the auto trans (PRND2L) have never worked for as long as i can remember and i have no clue how to fix it
Old Jun 23, 2007 | 10:21 AM
dbwan's Avatar
well my dads speedo isn't working either so he can't tell how fast he is going. You guys think it might be the speed sensor?
Old Jun 23, 2007 | 03:24 PM
DAS_GTI's Avatar
fuses
Have you checked the fuses? There is probably a couple different fuses for the various interior lights.
Old Jun 23, 2007 | 09:20 PM
dbwan's Avatar
yea i have besides this problem the car drives fine
Old Jun 24, 2007 | 01:49 AM
Corbit's Avatar
Could it be a bulb ? Or a unplugged connector ? I dont know how that end of it is set up , but I had a bad speed sensor and it didn't cuase the light to go out.
Old Jul 19, 2007 | 02:15 PM
Belize Off Road Team's Avatar
it sounds like its just the lights, just have to replace them. my temp control light has been out since i owned my 4Runner (1.5 years and counting).
Old Jul 19, 2007 | 03:07 PM
breknraj's Avatar
Does this mean that all the dash lights are out?
If so, check the dimmer knob to make sure it is turned up (easy to forget about), or it could be burnt out.
Old Jul 19, 2007 | 06:13 PM
Robrt32's Avatar
My speed hand fell to 0 the other day coming home.. It had always taken it a minute to start working.. I would get a couple mile from the house it would kick up to the speed i was running but after about a 75 mile trip the other day it fell to 0 and has not moved since.. I checked to make sure the speed sensor was pluged in , the connection looked clean and not dirty.. The sencor must be bad.. anybody ever changed 1? are they expensive?
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
Steezy96yota
Jul 6, 2015 10:00 AM
wilbertd
Jul 6, 2015 07:39 AM
