diff leakin - what do I need to fix this?
Old Jun 25, 2007 | 01:57 PM
ken.vs.ryu's Avatar
Question diff leakin - what do I need to fix this?
Hopefully it's just a couple of seals.
Old Jun 25, 2007 | 02:26 PM
Bigblock's Avatar
A seal and a yoke and an FSM!
Old Jun 25, 2007 | 03:00 PM
ovrrdrive's Avatar
Could you be a little clearer as to where it's leaking?
You may just need some brake cleaner and permatex...
Old Jun 25, 2007 | 03:38 PM
4Crawler's Avatar
If it is leaking around the mating surface, one option is to snug up the nuts on the studs. Take care you don't snap them off, I think they only take around 19 ft.lb. torque on those. If that does not do it, you'll need to pull the 3rd member out then clean the mating surface and apply some sealant and reinstall the 3rd.
Old Jun 25, 2007 | 03:46 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
yeah you should clarify where its leaking...could even be the drain plug or something
Old Jun 25, 2007 | 03:52 PM
Jay351's Avatar
If its leaking from where the 3rd bolts to the axle housing you need a new gasket, so you will have to pull the third and axle shafts to get at it.
I have to do mine
Old Jun 25, 2007 | 04:50 PM
ovrrdrive's Avatar
I have to do mine
I've never bothered to get a gasket for that flange. All you need is permatex or sealer...
Old Jun 25, 2007 | 09:22 PM
Jay351's Avatar
I already got the gasket. was only a few bucks..
Old Jun 25, 2007 | 09:37 PM
gonzo's Avatar
Might be just the vent on the top stuck from dirt or rust.
NEED MORE INFO
Old Jun 26, 2007 | 12:35 AM
ovrrdrive's Avatar
Umm, it's not your diff that's leaking in the pic above...
Old Jun 26, 2007 | 08:04 AM
PirateFins's Avatar
give us a pic from the front of the 3rd where the d-shaft attaches to the pinion flange. Mine is leaving drips like that do to a bad pinion seal, but hard to tell from the back picture.
Old Jun 26, 2007 | 08:07 AM
881stGenRunner's Avatar
i believe that is called the companion seal and i have heard they are fairly easy to change.
Old Jun 26, 2007 | 08:17 AM
PirateFins's Avatar
Yeah I've heard it called both, and it is easy since I had to do it once allready about 4 years ago.
Old Jun 26, 2007 | 01:46 PM
ken.vs.ryu's Avatar
You guys are great! Here's a 2nd shot.
Old Jun 26, 2007 | 01:56 PM
MudHippy's Avatar
Oh, fill plug gasket. That's super easy to fix. Was that a gag saving that pic till last? Just to see if people might guess that?
Old Jun 26, 2007 | 02:13 PM
gonzo's Avatar
Hm. I don't see any pics. LOL
polo451
13
Nov 20, 2016 07:49 PM
jerusry
Oct 19, 2015 05:28 PM
jaretstuff
Aug 4, 2015 02:08 PM
Steven.m.paulk
Jul 24, 2015 01:44 PM
scottyg486
Jul 19, 2015 05:34 PM
