O/D and Check engine light flashing...
Old Jun 28, 2007 | 05:25 PM
PoleVaulter95's Avatar
well as the title says the over drive and check engine light are flashing. i got in my 4runner (95 4runner 3.0 auto 4x4) after practice and those two lights we flashing. so i turned the engine off and popped the hood everything seems to be fine. my house is a couple of miles away so i just drive it. drives fine except has kinda a lag in the throttle at first then nothing is wrong. also when i floor it the over drive and check engine light would go off. anyone have any idea whats going on? all suggestions are appreciated inlcuding how to turn these lights off.
Old Jun 28, 2007 | 05:36 PM
PhillipsRA's Avatar
is your overdrive button pushed in on your shifter? on mine its on the passenger's side of the knob
Old Jun 28, 2007 | 05:40 PM
well i leave overdrive on around town but when i push it to turn it off it just lights up like normal telling me it is off but as soon as i turn it back on it will flash again im giong outside to pull the efi fuse and let it sit and think about what it did for a minute
Old Jun 28, 2007 | 06:00 PM
CJM's Avatar
CJM
Thats some kinda idiot light error code, dunno what it means but its def. something not right in there.
Old Jun 28, 2007 | 06:12 PM
well i went back out and put the fuse back in and reconnected the battery and got the same thing. the worst part is it wont let me check the codes (connect e1 to te1) because it just stays there blinking... i need some help on this one guys
Old Jun 28, 2007 | 06:19 PM
PhillipsRA's Avatar
i ain't too bright w/ wiring....sorry, last time i wired somethin i electrocuted myself and fell off a ladder (i thought the power was off)
Old Oct 22, 2007 | 01:48 PM
NassauBob's Avatar
Lightbulb O/D Off light blinking
Well, let me tell you my story on this. I got my transmission rebuilt, and the O/D Off light started blinking. I looked all over the internet, and got info basically telling me that a solenoid was malfunctioning. So back to the shop I went...and he told me that it wasn't covered in the warranty, and it'd be about $300 for a new one!
I did a little poking around on the truck, because according to the info I was getting, my truck (a 1994 'Yota 4X4) shouldn't be shifting into O/D at all, and it was. What I found was silly - a plug, on the passenger side of the transmission, near the shift linkage, was barely pushed up on the socket. I ran back into my shop and got a zip tie, and secured the plug in the socket.
When I drove it, and still to this day, I have had no O/D Off light.
Here's another goof - my transmission mechanic (well, my EX-mechanic, that is!) forgot to put two bolts back on the bell housing when he did the overhaul. How messed up is that!!!
Later people, hope this tidbit helps!
Shane
'94 'Yota 4X4
22RE
auto tranny
ROLL TIDE
Old Dec 26, 2019 | 12:19 PM
Toyout's Avatar
What was your fix? I'm having the same problem.
thinking maybe a solenoid problem but not sure yet.
Old Dec 26, 2019 | 12:46 PM
scope103's Avatar
The SAME problem? Same as what? A good description is pretty essential to get a good answer.
Here's the manual: http://web.archive.org/web/201408161...31diagnosi.pdf Read the codes, and let us know what you find. Don't forget to tell us what vehicle you're talking about (make/model/year/engine/transmission/ ....)
Old Dec 26, 2019 | 03:52 PM
wallytoo's Avatar
dredging up a 12 year dormant thread may not provide answers from the person queried.
Mickeybas
Mar 12, 2015 03:21 AM
slemay6
25
Jun 30, 2012 01:47 PM
kanyonkritter
Apr 9, 2010 09:00 AM
dasch
Mar 14, 2005 07:10 AM
BigJohn
May 22, 2004 02:58 PM
