Rear window switch
Old May 13, 2006 | 04:42 PM
bigpest88's Avatar
Rear window switch
Since I have bought my 4runner 3 years ago, the rear window switch dose not work. The window will go down with the key, but its a PITA to turn the truck off and use the key to lower the rear window. Any sugesstions on what could be wrong? Thanks
ChRiZ
Old May 13, 2006 | 06:39 PM
regularguy412's Avatar
Try shooting some electrical contact cleaner in and around the console switch. Worked for me. I also had a problem with moisture getting in the rear gate due to some loose, lower weather stripping. You might also check for loose or corroded grounds in the rear gate.
Mike in AR
Old May 13, 2006 | 09:17 PM
bigpest88's Avatar
Well, what i did at first was replace the switch and it worked perfect for about a month, and it too stoped working.
Jun 1, 2021 01:51 PM
coreyedwards7611
Jan 16, 2016 06:38 PM
icentropy
Jul 14, 2015 10:23 AM
Johntom240
7
Jul 13, 2015 12:18 AM
coryc85
Jul 6, 2015 04:07 AM
