Rear window switch
Since I have bought my 4runner 3 years ago, the rear window switch dose not work. The window will go down with the key, but its a PITA to turn the truck off and use the key to lower the rear window. Any sugesstions on what could be wrong? Thanks
ChRiZ |
Try shooting some electrical contact cleaner in and around the console switch. Worked for me. I also had a problem with moisture getting in the rear gate due to some loose, lower weather stripping. You might also check for loose or corroded grounds in the rear gate.
Mike in AR |
Well, what i did at first was replace the switch and it worked perfect for about a month, and it too stoped working.
