3.0 Overheating problem
Old May 10, 2006 | 06:49 PM
jsrusse11's Avatar
Newly rebuilt motor, new thermostat fan clutch seems new, and fresh toyota coolant. Wants to overheat when driving in town after 10 or 15 minutes. Fine on long drives. Everything seems to be running fine. any ideas?
Old May 10, 2006 | 09:43 PM
DirtCheap's Avatar
Check your fluid level. Could be defective fan clutch or clogged radiator.
Old May 11, 2006 | 02:32 PM
jsrusse11's Avatar
fluids fine, how do i check for a clog?
Old May 13, 2006 | 04:08 PM
WhlnRunner's Avatar
Where to start? factory fan clutch? aftermarkes clutches are garbage. radiator could be clogged. radiator and ac condenser could be full of dirt. clean with compressed air and water hose. fan clutch#16210-65020.
factory t-stat 90916-03079. aftermarket t-stats don't work. also make sure the coolant is properly bled.
Old May 13, 2006 | 04:56 PM
snap-on's Avatar
i think the radiator problems are unlikely.
my guess is thermostat. Its fairly easy to pull it out and put it back together without it in. IF it does fine with out it, toss it and get a new one.
if your still haveing problems after you pull the thermostat, move on to other stuff mentioned...
Old May 14, 2006 | 07:21 PM
williemon's Avatar
You said newly rebuilt. If the heads were removed and reinstalled, the head gaskits could have been installed backwards. It happened to me. Only way to tell that I know of is to pull the heads.
Old May 15, 2006 | 08:21 AM
jsrusse11's Avatar
nevermind my buddies an idiot. he changed his coolant from green to toyota red and didn't totally get it drained. So I guess green and red clump up and clog the hell out of everything.
Old May 20, 2006 | 10:51 AM
StoogeBrother's Avatar
Check for air bubble in system. Remove heater hose behind eng. next to firewall... fill w/coolant...reconnect.... set rad. cap at half turn... run eng. for 10 min. Cool down and refill any missing coolant
Old May 20, 2006 | 10:52 AM
Dont worry about mixing coolant types.. no prob.
Old May 20, 2006 | 05:12 PM
tc's Avatar
tc
Disagree and have the receipt for a heater core to prove it. Don't mix types - it's not worth it.
the1998sr5
15
Jul 14, 2020 08:35 PM
Alex Bessinger
Aug 31, 2015 09:17 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
the1998sr5
Jul 16, 2015 06:20 AM
Avenged
Jul 9, 2015 07:55 AM
