Help with 1989 4Runner
Old Apr 30, 2006 | 08:21 PM
peacedog's Avatar
Please help. I ahve a 1989 4Runner that was running great before tonight. I went to start it up and it is looping (800 rpm to 1300 rpm) and running rough. In fact I probably can not drive now because it is running soooo rough. Is it the infamous headgasket or maybe a quick fix and help would be great. Thanks.
Old May 1, 2006 | 05:11 PM
Elton's Avatar
do you have a 3.0 or 22re
Old May 2, 2006 | 02:41 PM
peacedog's Avatar
It is a V-6. I talked with a Toyota tech and he said could be the throttle indicator or something like that.
Old May 3, 2006 | 05:46 AM
mtrdrms's Avatar
Check for a vacuum leak. My runner had similar problems and it turned out the EGR valve was broken and I couldnt see the break.
Old May 3, 2006 | 05:48 AM
mtrdrms's Avatar
Check here: https://www.yotatech.com/forums/show...hlight=surging
Old May 3, 2006 | 04:24 PM
peacedog's Avatar
Thanks for the info guys. I am going to look at the 4Runner tonite and I have a friend who is a tech come over the weekend. Please keep the suggesting coming.
Old May 3, 2006 | 04:30 PM
Jeffires's Avatar
Problem with the AFM in the top of the airbox can cause stumbling, and engine will stall when you try to take off.
Are there any other symptoms like noises, smoking, check engine light?
Old May 4, 2006 | 09:28 PM
Adampops's Avatar
I experienced the same thing on my 94 Acura Integra.
I ignored it because I am an idiot and still drove it everyday.
Now she is dead! It ended up being the head gasket and coolant leaked into the engine causing hydrolock. She is going to cost more to fix than she is worth so I am donating her to some charity.
I'm not saying that it's the headgasket for sure, but it is a possibility especially given the headgasket problems.
Flying91
45
Apr 11, 2024 04:39 PM
icentropy
Sep 16, 2020 02:47 PM
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
