22 RE misfire
Old May 14, 2006 | 09:25 PM
art's Avatar
art
22 RE misfire
1989 xtra cab 4x4 22 RE 5 spd. OK I have a no load misfire from idle to about 3,000 rpm. The strange part is that it only occurs when the engine is completely warmed up. When the engine is cold I can not feel or hear the miss. The misfire can not be felt while driving. thanks
Old May 15, 2006 | 03:28 AM
TNRabbit's Avatar
Sounds exactly like my problem with a 3vze V6. I think I've tracked it down to the Throttle Position Sensor (TPS)...is yours showing any codes on the ECU?
Old May 15, 2006 | 06:13 AM
art's Avatar
art
The light is not on. Do I need to check the ECU with a reader or just the wire technique?
Old May 15, 2006 | 08:00 AM
TNRabbit's Avatar
wire technique.
Old May 16, 2006 | 08:27 AM
art's Avatar
art
I'll try that when i get home tonight. Thanks
Old Mar 8, 2008 | 10:10 AM
cutboggers's Avatar
Question.
If the check engine light is off.
Will your computer still show a code if something is wrong?
I know a friend with a 93 22re. It's kinda sluggish sometimes under 3000 or not at WOT. No check engine light. Brand new rebuild.
Old Mar 8, 2008 | 10:23 AM
muddpigg's Avatar
Mine was doing the same thing. diagnosed for a couple months. Turned out to be the EGR, made a cut off plate and gasket so its sandwiched. No more miss. When I got an extra pocket for of cash I'll replace or when I find a good used one.
Old Mar 8, 2008 | 11:20 AM
cutboggers's Avatar
thanx.
I'll try that. Personally I'm a believer of blockoff plates :o)
So prob nothing to do with MAF or TPS so don't waste my time and his money?
shooter86314
Jan 7, 2016 07:05 AM
Firefightersink15
Nov 23, 2015 10:32 PM
calderp
Nov 16, 2015 02:49 AM
the_supernerd
Oct 1, 2015 09:20 PM
larrys93pickup
Sep 17, 2015 07:05 PM
