rusted cab mounts
Old Apr 29, 2006 | 01:17 AM
tilac1's Avatar
rusted cab mounts
The rearmost frame/cab mounts (just below the seat) on my '91 4x4 have completely rusted out what's the easiest way to fix this?
Old Apr 29, 2006 | 01:37 AM
rocket's Avatar
Good advice...
Originally Posted by 4Crawler
A few tips:
#1. Use a real penetrating oil, something like PB Blaster, Kroil, etc., not WD-40 or silicone spray. A good penetrating oil will soften the rust and work it's way into the threads given some time to work.
#2. Blue wrench (that is a propane torch's blue flame). Heat up the nut as hot as you can and then try removing it either hot or after it cools.
#3. One good trick is to heat the nut up fairly hot and then melt some candle wax (parafin) and let the heat suck the wax into the threads.
Old Apr 30, 2006 | 02:20 AM
tilac1's Avatar
mounts gone
The frame mounts have rusted off completely, the back of the cab is "floating" not attached to the frame. Looks like welding on new ones is the way to go, just wondering what others have used, angle iron?
young buck
18
Aug 27, 2018 02:40 PM
gieselman
Mar 20, 2016 04:34 PM
Robojd1
23
Jul 21, 2015 01:43 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
HaydenConQueso
Jul 12, 2015 05:22 PM
