3vze High Idle???
Old May 14, 2006 | 03:45 PM
paintball11090's Avatar
3vze High Idle???
I have a '94 4Runner with the 3vze and 187k miles. When I drive it and stop at a light or someting when I take it out of gear and stop the engine will go up to/stay at 1,500-2,000 rpm untill I blip the gas and it will go back down to 900-1,100 rpm. I am planing on doing seafoam sometime this week. Has anyone had this problem before? If so will the seafoam fix it?
Thanks alot,
Greg
Old May 14, 2006 | 05:14 PM
tc's Avatar
tc
It could be a sticking throttle cable/linkage, and Seafoam may help. Cleaning/lubing the cable might work too.
Or it could be a little deeper - like the TPS.
http://www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old May 14, 2006 | 08:16 PM
^VooDoo^'s Avatar
Clean Throttlebody, Check TPS for adjustment.(Dont get cleaner on TPS or it may be damaged)
Check the slack in the throttle cable, or not enough. (Check little grommet on the throttle cable meets the gaspeddle it can be sneaky)
Old May 14, 2006 | 08:29 PM
Tofer's Avatar
Sponsor
mine is doing the same thing. i am waiting to get home (next week) before i dig into it and try to find out whats wrong. i'll let you know what i find.
Old May 31, 2006 | 04:38 PM
ReneB64's Avatar
I have this same problem with my 1993 4x4; the mechanic has blown out the tps with air, he claims gunk gets on the wiper causing problems. Works fine for a while unit problem comes up again.
tomczaksdiesel
Jul 26, 2015 10:35 PM
greenbuggy
3.4 Swaps
Jul 23, 2015 11:51 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
