All-Pro rear bumper and exhaust
Old May 10, 2006 | 10:44 AM
AH64ID's Avatar
I am within a few days of getting my new exhaust bent up. I can't decide how to route the tail pipe, so where else would I get the best knowledge....
Lets see pics of your tail pipe, stock and custom, with an allpro rear bumper, and what you do and dont like about it....
Old May 11, 2006 | 10:52 AM
AH64ID's Avatar
So no-one hear has an allpro rear bumper?
Old May 11, 2006 | 10:54 AM
Elton's Avatar
give it some time
Old May 11, 2006 | 10:57 AM
AH64ID's Avatar
it was more of a question to say something other than bump
Old May 11, 2006 | 10:59 AM
cootees's Avatar
This is for a pickup and not a runner, correct?
Why not run it back to the factory exit location?
Old May 11, 2006 | 11:14 AM
AH64ID's Avatar
From what I recall, my tip rusted off before I got the bumper on, is that the tail pipe is quite a bit lower than the bumper. I dont want it where it can get hung up.
4runner or P/U doesnt matter, the bumper and tail pipe are very similar. On my runner I had the tail pipe come out in the front of the bumper and the bumper height. But I now have 35's and that might be a bit tight??
Just looking for other ideas
Old May 11, 2006 | 11:23 AM
cootees's Avatar
ok, the reason I asked pickup or runner was because of exiting in the rear... If it were on a runner and you made it exit out the back then the fumes would come straight in when the window is down.
If you are worried about clearence and don't mind using a hole saw then what I would do is cut a hole in the side of the bed where the factory bumper wrapped around and exit the exhaust their.
heh.. let me know if that makes sense.
Old May 11, 2006 | 11:34 AM
AH64ID's Avatar
Yeah it makes sence, I am not a big fan of straight back exhaust. It makes trailers black, and I carry stuff on a hitch-haul.
Old May 11, 2006 | 11:39 AM
cootees's Avatar
yeah, neither am I. I'll see if I can chop a picture later to give you a better idea of what I am talking about. Basically it would still be in the factory positioning only raising it up higher.
Old May 11, 2006 | 11:42 AM
pinnacle's Avatar
Here is mine. They are kind of hard to see. Mine is going to get cut off once I get my new springs and shackles.
Old May 11, 2006 | 11:49 AM
AH64ID's Avatar
That looks good... I already have the 56"ers in, not they they affect my shackle. I could come under the frame in front of the shackle and dump it like that.
Here is what my runner had, I routed it to the pass side because it was too loud on the drivers :-) I wont do that this time though.
If you look close above the right rear you can see the pipe infront if the bumper.
Old May 11, 2006 | 12:02 PM
pinnacle's Avatar
I'm going to see how loud it is with the top off. With it on its not too bad. I can hear it but its not real loud.
I'm going to run 62" springs. It will be in the way of the shackle.
Old May 11, 2006 | 02:28 PM
Toyopnoy's Avatar
How much lift do the 62" give approximately?
Old May 11, 2006 | 02:34 PM
AH64ID's Avatar
Probally depends on what they are made for, could be custom and provide any number you want. Stock chevy leaves, I think 63", can be good for about 4".
Old May 11, 2006 | 04:26 PM
pinnacle's Avatar
They have 3 different arches. 10.5"(0" lift), 12.5", and 14.5". They are ment to be run spring under. Lift depends on the arch, length of the shackle and where the shackle is mounted.
Old May 11, 2006 | 04:59 PM
AH64ID's Avatar
Haha--hijacking my own thread....Who makes these? Are you going spring under for the axle wrap? Where do you do most your wheeling? I dont see many people going TO a spring uner....or is that just what they are made for, and what rig is that?
Old May 11, 2006 | 05:08 PM
pinnacle's Avatar
Sorry about the hijack.
Deaver makes the springs. I does reduce axle wrap, but mostly used to gain wheel travel. I hoping to get around 17.5-18" of travel out of the springs. I'm mostly into desert racing and 4x4 stuff, not rock crawling.
Old May 11, 2006 | 05:14 PM
AH64ID's Avatar
Thats cool.... so you'll get 18" of travel at both wheels at once.... I can get 19 or so from my alcans, but it requires stuffing the other side... Should be sweet for hi-speed runs
Old May 11, 2006 | 05:26 PM
pinnacle's Avatar
Yeah both wheels at once. Not sure what it would pull articulted.
Example at full droop
Old May 11, 2006 | 05:28 PM
AH64ID's Avatar
interesting shackle mounts, but thats some droop...
