Does No front sway bar = Damage?
Old May 11, 2006 | 04:37 AM
mtrdrms's Avatar
I just recently noticed that my drivers side front sway bar end link is broken. Should I fix this immediatly? Will it do any harm if I drive it like that for a while?
Old May 11, 2006 | 05:28 AM
midiwall's Avatar
You'll probably do more harm with the potential of something getting caught on the broken end. I've been driving wihtout a front sway bar (it's totally removed) for about a month and don't plan on putting it back in.
It's a little loose up front, but nothing "bad".
Old May 11, 2006 | 06:10 AM
TNRabbit's Avatar
The bar you are referring to is actually an "ANTI-sway" bar, used to prevent excessive "lean" in cornering and it also tames the tendency to understeer. It will also help control induced oscillation (when you whip the steering one way they quickly back the other and the rear end gets "happy"). Many off roaders remove the bar entirely because it enables the suspension to keep both wheels on the ground in extreme flexing off road manuevers. Your choice, really. I'd retain it if you do an lot of highway travel, get rid of it if you run low mph & are off road.
Old May 11, 2006 | 06:17 AM
mtrdrms's Avatar
Got it. I was just worried about overstressing any front end equipment (i.e. ball joints, cv, etc) without the added support of the swaybar. Thanks
Old May 11, 2006 | 06:18 AM
VA_Yotaman's Avatar
I've had mine disconnected on my 91 for about 5 years. I was never able to tell any difference.
Old May 11, 2006 | 07:32 AM
Bobakazi's Avatar
It is a cheap fix, and easily done. I would repair it if you drive mostly on the road. Then you will know how to disconnect it for offroad. If you leave it as-is, it could get worse and stop flopping around.
Old May 11, 2006 | 07:52 AM
Blizzard's Avatar
I have a link broken since something like 1 year ago... It's half/half between connected and disconnected hehehe
David
Old May 11, 2006 | 09:40 AM
trythis's Avatar
I replaced the rubber grommets on mine, but while I was doing that, I had to run back to the store with no anti-sway bar. I didnt notice a difference, but when I put the new bolts, and rubber grommets (polyester style) I noticed a difference. Much less lean on and off highway ramps than before changing out the rubber cylinders.
Old May 11, 2006 | 03:20 PM
tc's Avatar
tc
David
me too (well, not a year - prob a month or so)
Old May 11, 2006 | 07:19 PM
40_Below's Avatar
Doesn't removing the sway bar create nasty CV angles?
Old May 11, 2006 | 07:49 PM
Tanto's Avatar
no. it just reduces body roll in taking corners.
Old May 11, 2006 | 08:15 PM
brandontrek's Avatar
i like the sound of that!!! i might disconnect mine...haha...jk
88sasturbotoy
Jan 30, 2026 01:57 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
