Battery discharge light came on!
Old Apr 28, 2006 | 01:34 PM
mtrdrms's Avatar
Well I should have left well enough alone. I washed the engine bay (carefully) and now my battery light and my emergency brake light stay on. DAMMIT! Does this mean I fried my alternator? What does the brake light mean? What else would trigger these lights? 89 4runner 3.0 5speed. Thanks
Old Apr 28, 2006 | 01:40 PM
Jeffires's Avatar
Take off the battery negative and reset the computer. That's always the first thing I try. Take it off for a few minutes, then reconnect it.
Old Apr 28, 2006 | 02:40 PM
mtrdrms's Avatar
Well I was driving home before and the volt meter started dropping and the truck ran real bad and finally died just before I got into my driveway. So I am left to assume the alternator is shot. Looks original. Anything else it could be?
Old Apr 28, 2006 | 02:47 PM
midiwall's Avatar
I dun't tink so... that REALLY sounds like an alternator.
Old Apr 28, 2006 | 03:07 PM
91_4x4runner's Avatar
That sucks... my sister had her alternator go out on her while she was driving (original). I'm also voting for alternator. Maybe it's time for an upgrade?
Old Apr 28, 2006 | 03:13 PM
Jeffires's Avatar
Now that I hear the rest of the symptoms, I agree - remove the alternator and have it bench tested.
Old Apr 28, 2006 | 03:16 PM
mtrdrms's Avatar
Upgrade as in a better alternator?
Old Apr 28, 2006 | 03:57 PM
84sr5yoty's Avatar
Copied from 1sttoyotaparts.com by Sidney:
If the brake and charge lights come on during revving of the engine then it's a sign that the carbon alternator brushes require replacing as this is the mileage for them to wear out. In alternators the brushes wear out on average every 140-170 000 miles where on the dashboard the brake & charge light both come on at the same time. About half of the auto electric shops in your local yellow pages sell carbon alternator brushes and copper solenoid starter contacts for about $5/pair.Another way to verify that the alternator is not charging is while the engine is running bring a metal screwdriver or any metal object near the alternator and if the alternator is working properly then it should act like a magnet and grab the screwdriver.
For carbon brushes R&R:
http://www.4x4wire.com/toyota/mainte...rnator_brushes
http://www.toyotaoffroad.net/afertig...torbrushes.htm
http://perso.wanadoo.fr/adherence.4x...nateur_kzj.htm
http://www.automotiveforums.com/vbul...d.php?t=166525
http://www.toyotanation.com/forum/sh...270&forumid=10
http://www.pirate4x4.com/forum/showt...r+brush+holder
http://www.bitwalla.com/cruisers/art...lternator.html
http://www.barneymc.com/toy_root/tec...c/altrnatr.htm
For decoding the dashboard lights:
http://www.powerbase-auto.co.uk/alternator_faults.htm
http://members.1stconnect.com/anozir...alternator.htm
Here are part #'s for Toyota alternator carbon brushes and copper solenoid starter contacts which are used in about 95% of all Toyota vehicles.
Toyota alternator Brushes with holder:
Toyota # 27370-35060=$29 CDN
Honda # 31105-PZ1-003
Metro # 39-82003 (www.metroautoinc.com ,Pomona,California)
Unknown brand name # F4019-53035
Alternator brush only (qty:1 brush unless otherwise stated):
AC Delco # E724
AC Delco # E731 (side wire and concave tip)
Ace Electric # DA-61 (brush only),S-5367 (brush holder)
Beck Arnley # 178-1669 (side wire and concave tip)
Beck Arnley # 178-1376
Borg Warner # X580 (side wire and concave tip)
Canadian Tire # 19-2050-6=$4.49/pair
Daihatsu # 27370-87302-000
Daihatsu # 27371-63020-000
Daihatsu # 27371-87501-000
Daihatsu # 27371-70300-000
Echlin # E601=$8.16 CDN/pair (UAP/NAPA)
Echlin # ECHE601
Echlin # EC480
Echlin # ECHE480
GP Sorensen # 255047 (side wire and concave tip)
GM # 94123056
GM # 96054118
Honda # 31144-PD1-004=$9.72
Honda # 31144-PD1-0040
Honda # 31144-PD1-0030
Honda # 31150-PR7-A01
Honda # 31150-PTO-003
Hino Industries # 021660-0390
Hino Industries # 021660-0510
Isuzu # 8-94123-056-0
Isuzu # 8-97032-308-0
Isuzu # 8-97032-310-0
Mazda # 021660-0390
Mazda # 021660-0510
Mazda # KL47-18-W75
Metro # 38-82001(side wire concave tip) (www.metroautoinc.com ,Pomona,California)
Mileage Plus # E601SB
Mitsubishi # MD604474
Mitsubishi # 21660-0510
Niehoff # WA571 (side wire and concave tip)
NipponDenso # 021660-0390
NipponDenso # 021660-0510
Standard # JX-116 (side wire and concave tip)
Subaru # 021660-0390
Subaru # 021660-0510
Suzuki # 31631-82610
Suzuki # 31656-82611
Suzuki # 021660-0510
Toyota # 27370-42010
Toyota # 27370-75060
Toyota # 27371-63020=$5.80 (up to 9105) (side wire and concave tip)
Toyota # 27371-70300=$5.20 (9105-9511)
Toyota # 27371-76004-71
UAP/NAPA # MPEE601SB
Victory Lap # FAX57=$4.49 CDN/pair (Canadian Tire)
Wilson's Electric # 26-29-7534 (side wire and concave tip)=$2.20 each CDN (Diesel Auto Electric)(Parts for Trucks,box of 10 for $3.40 CDN)
Specifications:
Length=15 mm
Width=7 mm
Thickness=5 mm
Lead length=49 mm
Old Apr 28, 2006 | 05:04 PM
Newer/better typically the same thing when buying stuff for your vehicle. But yeah, I'd go for a better one, like one that works. Doesn't have to be new.
Old Apr 29, 2006 | 08:23 AM
Blair's Avatar
Alternator brushes - $5.00 at any auto electrical shop. Get the pre-fab set for $10.00, already in the assembly.You just pull the alt., open the casing, remove the two screws (careful to use the right size screwdriver here), replace the assembly, put the case back on, install and go.
Or, the GSR method will get you through to next month, maybe. GSR = Good, Sharp, Rap - to the back of the alt. Helps to extend the brush life by about 1 week / rap.
Yota.Jay
28
Oct 22, 2015 01:08 PM
AkitaDog
Sep 1, 2015 08:05 AM
mluz013
Jul 24, 2015 12:31 PM
Sandman
Jul 14, 2015 12:36 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
