22RE Hoses and vacuum line pics needed please
Old May 6, 2006 | 03:54 PM
EWAYota's Avatar
Trying to button everything on my 22re, all thats left I hope is hooking up the vacuum lines and other hoses and then some other things. I tried to follow the vacuum diagram in the chiltons as best I could but am missing something somewhere and this is what I have left to figure out.
This is on top of the throttle body. I'm not sure where this goes:
This one is on the bottom of the throttle body:
and this is under all the other hoses and air pipe:
I am lost on those. I also have this part left that I need to figure out where it bolts down too. This is in-part of the bundle that goes under the intake, and I think it bolts on the side closest to the pass. fender of the air intake chamber, but again, have no clue. It looks like its a ground wire of some sort. maybe bolting to the top of the valve cover is another thought?
I've searched a few threads, looking for photos of the 22re, but cant find any clear enough for me to decipher.
Old May 6, 2006 | 04:31 PM
EWAYota's Avatar
this is what i've been looking at, but i can't make out everything due to the distance
https://www.yotatech.com/forums/show...0&postcount=18
Old May 6, 2006 | 05:01 PM
Flash319's Avatar
Here are some pics.
Old May 6, 2006 | 06:08 PM
EWAYota's Avatar
thanks. the last one, looks like theres a connector that goes over it, i just can't seem to find it. do you know whats on the other end of that?
Old May 6, 2006 | 08:05 PM
EWAYota's Avatar
Bump
just out of curiousity, what part is this, and where does the other end of what ever connects to this connect at?
Old May 6, 2006 | 10:06 PM
BLKNBLU's Avatar
Mine looks a little different than flash319
Here is another view. I think he doesn't have a valve that I have. It appears mine goes TB/valve/PS pump and his goes straight TB/PS pump.
Old May 6, 2006 | 10:41 PM
BLKNBLU's Avatar
Not sure about your item in pic 3 of your post. Flashes pic and mine below are about halfway back on the head, but it is an electrical connection, not vaccum. But the other surrounding hoses look right.
Then there is this sensor below the TPS that has vaccum lines, but if that is what you're looking at yours is broken off. If that is what you are looking at, I will try to get you better pics.
The wire you show in your last 2 pics didn't have a nut and bolt like yours on my truck. It just attaches to the nut and stud on the back/bottom intake like so.
Hope this helps.
Mike
Old May 7, 2006 | 04:05 AM
Flash319's Avatar
That is a Temp sensor switch that the connector is plugged into. Not sure if it is for the dummy light or ECU but my guess it is just for the dummy light. BLKNBLU has another smog thing or something that that first line goes to then to the power steering. Not sure what it is. My truck is an 89 and bought in Canada.
Old May 7, 2006 | 07:38 AM
EWAYota's Avatar
Hope this helps.
Mike
thats the one i'm trying to find. where does that wire go to? I have a feeling its just dangling somewhere but I can't find it.
I got all the other ones hooked up. The ones that look broken on mine, never had a sensor (since I've owned it atleast) so it looks right to me, lol.
Old May 7, 2006 | 09:15 AM
EWAYota's Avatar
found it. thanks for the photos
Old May 7, 2006 | 09:51 AM
BLKNBLU's Avatar
Good deal. Did you get the TB hoses on the bottom sorted out?
zd92655
Mar 6, 2022 12:58 PM
JF9243176
Oct 8, 2017 04:21 AM
BigArt70
Jun 30, 2015 09:51 PM
JF9243176
Jun 24, 2015 04:53 AM
HALMAN
Jun 14, 2002 09:02 PM
