22RE water pump replacement - advice?
Old Apr 30, 2006 | 05:14 PM
dealj's Avatar
My father-in-laws's 94 P/U (used to be my truck til' I gave it to him last month) has a squealing/grinding noise coming from the vicinity of the water pump pulley. I also noticed what looks like crystalized coolant on the water pump housing. Am I right in assuming that the water pump is on the verge of failure? If so, is it difficult to replace. My Hayes manual makes it seem fairly simple.
Does anyone have any advice/wisdom that they can impart??
Thanks in advance!
Old Apr 30, 2006 | 05:48 PM
kyle_22r's Avatar
it's not very hard to replace. just drain the coolant, remove the fan shroud, loosen the alternator belt and unbolt the fan pulley.
run a thin bead of gray RTV on the gasket when you install the new pump, and all should be good.
voiddweller
19
May 2, 2016 09:10 PM
Ichneumon
Sep 27, 2015 04:21 PM
noahstancik
Jul 10, 2015 11:18 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
infinityisfive
Jun 16, 2015 06:51 PM
