air conditioning problem '92 4runner
Old May 7, 2006 | 08:34 PM
smackay's Avatar
The A/C on my '92 4runner ( 22re, 5-speed manual ) stopped working. The green light comes on in the button when pushed in, but the compressor doesn't engage. I've checked the circuit breaker and the fuse behind the glove box and both are intact. Does any one have any ideas about what I can do? Thanks in advance for any suggestions.
Old Jul 10, 2009 | 09:55 PM
SigEp4Runner's Avatar
So searching around I found this post, I'm having the same problem except my A/c never worked since I bought it. The light comes on, but the air is still warm. When I had it in at the dealership they told me it was "unplugged" whatever that means. I asked if they could "plug it back in" and they wanted around $200 to do it!! So I've been driving around for about two years without A/C and decided to start looking into fixing it myself.
Any Ideas????????
Old Jul 11, 2009 | 02:17 AM
cdextreme's Avatar
With the key out of the ignition, grab the center of the a/c compressor. You should be able to move it. if you can't you have a seized compressor.
If you have a low/high charge there are switches that prevent the system from running and damaging parts.
Old Jul 11, 2009 | 10:05 AM
ok so I checked that and it moved just fine. Is there any plugs I can check that the dealership would say were unplugged? I have seen while searching that if there is a high/low charge the light doesn't turn on on the A/C button, is this true? I was thinking about buying a charge kit, but my light still turns on. I was looking at a charge kit on ebay called Enviro-safe that is compatible with R12 systems and the oils mix without causing the harm that the 134 conversion kits will do. I found another post about the kit while i was searching this problem.
Old Jul 13, 2009 | 06:45 AM
RICE ETR's Avatar
I just charged my A/C and my light would come on but the compressor wouldn't kick-in until I had about 3/4 of a 12oz can of 134a in it. Blowing cold now...41 degrees F at idle :-) We'll see how long it lasts.
Old Jul 13, 2009 | 05:34 PM
thats good to hear RICE ETR, I was worried mine might be something worse. Did you do the R134? Im wondering what type I should use to recharge mine.
Old Jul 13, 2009 | 06:04 PM
RICE ETR's Avatar
Yea r12 is crazy expensive so I used 134a. I did it the absolute wrong way (don't recommend it) but have done it before and gotten away with it...I figure for $38 it was worth a shot, even if it only lasts thru the summer. New o-rings, a 16oz can of 134a with oil and leak stop plus another 12oz can of 134a. , I didn't get the old oil out, change the orfice or vacuum the system down, just charged it with the engine running on high on until the pressure was appropriate.
Old Jul 13, 2009 | 09:19 PM
yeah im thinking the same thing, there have been plenty of people saying they havnt had problems with the 134 in theres, but Im also thinking about the stuff I said up top. The kit comes with 3 cans of recharge, 1 can of dye, pressure guage, hoses, can of stop leak, can of new oil and a hand held thermometer for $60 shipped. i figure I might as well go that route for all it comes with if it says it wont harm the R12 systems. Thanks for the help, im hoping mine just needs a recharge.
Old Jul 21, 2009 | 04:38 PM
OK so I bought a kit from autozone, but i have some questions. First of all where is the high and low service valves? I think i see them on the left side near the firewall, but I want to be sure because i dont think the retrofit valves will fit. Also where do i need to replace the o-rings at?
Old Jul 27, 2009 | 07:00 PM
smallenginemechanic's Avatar
Low side is larger tube.
Old Aug 29, 2009 | 06:44 AM
Korey's Avatar
For years I tried to get mine fixed. Nobody could figure out what it was cuz the green light would come on but the compressor wouldn't engage. I found a disconnected wire near the battery on the passenger wheel well, found the other end of it and reconnected it.
If the dealer said it was unplugged and wanted $200, they were probably trying to get you to pay for their time looking for the disconnected wire.
bradstyle
Jun 19, 2018 03:15 AM
Ichneumon
Sep 27, 2015 04:21 PM
bigblue82
10
Jul 6, 2015 08:27 AM
greenmachine93
Jun 25, 2015 07:50 PM
