3vze Timing Belt component list
Old Jan 28, 2011 | 02:22 PM
91Toyota's Avatar
I just need a list of parts to replace while I'm doing my timing belt. My water pump just started leaking so I'm replacing the belt while I'm at it...it would be stupid not too.
Anyway, here is what I am thinking so far.
Timing belt
Tensioners
Waterpump
Thermostat
Cam seals
Front main seal
Anything else?
Old Jan 28, 2011 | 05:42 PM
Wrenchinjoe's Avatar
Idler pulleys (although perhaps that is what you meant by tensioners).
Accessory belts
Radiator hoses
Coolant
Don't know if I'd mess with the cam seals unless they showed signs of seepage. The cam pulley bolts are a real PITA to break loose.
You already have to remove the crank pulley bolt, so the front main seal is easy and cheap to replace at that point.
Old Jan 29, 2011 | 06:41 AM
meisentones's Avatar
When you get your water pump, be sure to specify manual or automatic transmission, as they are different. May save you a trip back to autopart store.
Old Jan 29, 2011 | 04:04 PM
91Toyota's Avatar
Yeah some have the side tube on it. Mine does, not sure why?
Old Jan 29, 2011 | 04:12 PM
hunter4runner's Avatar
the side tube is to the oil cooler mounted on the side of the block.
Old Jan 29, 2011 | 06:42 PM
KelleyC's Avatar
You also forgot FIPG black.
mskalmus
May 28, 2017 07:51 AM
bryan34w
Jul 6, 2015 05:53 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
toyoda8488
Jul 5, 2015 10:18 PM
