3vze Timing Belt component list
I just need a list of parts to replace while I'm doing my timing belt. My water pump just started leaking so I'm replacing the belt while I'm at it...it would be stupid not too.
Anyway, here is what I am thinking so far. Timing belt Tensioners Waterpump Thermostat Cam seals Front main seal Anything else? |
Idler pulleys (although perhaps that is what you meant by tensioners).
Accessory belts Radiator hoses Coolant Don't know if I'd mess with the cam seals unless they showed signs of seepage. The cam pulley bolts are a real PITA to break loose. You already have to remove the crank pulley bolt, so the front main seal is easy and cheap to replace at that point. |
When you get your water pump, be sure to specify manual or automatic transmission, as they are different. May save you a trip back to autopart store.
Yeah some have the side tube on it. Mine does, not sure why?
the side tube is to the oil cooler mounted on the side of the block.
You also forgot FIPG black.
