Charge, brake, and a.t. Oil temp light
Old Jan 26, 2011 | 05:14 AM
MilesToEmpty's Avatar
Well I went outside this morning, with 4" of snow on the ground.
Started up the 88 22re and had the brake light, battery light, and the a.t. Oil temp light were all on.
Let the truck warm up and restarted it, light didn't go away.
Any ideas?
Old Jan 26, 2011 | 05:25 AM
xxxtreme22r's Avatar
get your alternator and battery tested. Autozone or a chain store should be able to do it for you. I would start there. Curious why the A.T. light is on with those other two though.
Old Jan 26, 2011 | 10:15 AM
BigSwole's Avatar
When my alt went bad my at light was on as well. Replaced the alternator and it was good after that.
Old Jan 26, 2011 | 10:20 AM
metalhed's Avatar
Alternator going bad
Old Jan 26, 2011 | 07:22 PM
fireman1559's Avatar
x2 try to stay away from orileys they told me my batter was good and it had a dead cell and i had the alternator checked at autozone atleast 3 times and it was fine. like i would have to jump start the truck and it would start but the blower was weak and you couldnt have it on at the same time you had the head lights on and it had no power
Old Jan 27, 2011 | 12:53 PM
Well I went to start the truck today and it had no lights on...
Only difference was yesterday it was snowing, today everything was thawing.
Old Apr 5, 2011 | 06:25 PM
renzo sees's Avatar
Same problem with my 86 4X4 22RE..Problem started after heavy rains got under hood(horizontal rain!!) and shorted out the battery.(I know-I should keep battery top clean) Battery charged up after a jump, but lights remain on steady-no flicker. 14.2 volts when running and less than a year-old "locally-rebuilt" alternator(Not a cheeepo)
Old Apr 5, 2011 | 06:35 PM
I still ahve the issue... but I have tried a different known good battery and still have the problem.
Old Apr 5, 2011 | 07:25 PM
sebastianholmes's Avatar
as stated before, YOU NEED A NEW ALTERNATOR. i fried mine wheeling. the battery and brake lights are an indicator of a bad alternator. or it may have been frozen up somehow, but i doubt it.
Old Apr 12, 2011 | 08:40 PM
91_TOYOTA_4x4's Avatar
Yeah I just jumped my friends car yesterday and right after it my dag lights went dim, brake light came on, and the battery light wnt on too. My rear window is slow along with my sun roof too. Would my alternator go just from jumping a car? It's sounds like the alternator is gone which is fine, I will replace it, but it's kinda odd haha.
Old Apr 13, 2011 | 07:59 AM
spokane.yota.man's Avatar
It might not be a bad Alternator. Could just be a loose connection affecting the alternator. Also a common fix is to replace the brushes in the Alternator. that's a cheap and easy fix. Get a voltmeter gauge or a multimeter and see what the alt output is.
Old Apr 13, 2011 | 12:57 PM
Ok I will test it out in a bit. You may be right because when I turned a couple corners the lights would go off an verything would be normal for a sec? In gonna go mess around with it.
smthwsn357
May 1, 2024 07:28 AM
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
