swapping transmissions
Old Jan 26, 2011 | 06:53 PM
weakyota91's Avatar
i have tranny and transfer case out of my 89 22-re i need to swap out the transmission with another one. i have yet to drain the fluid out of the tranny or transfer case. when i seperate the t/case from transmission will i have gear oil everywhere if if dont drain them i know there seperate fluids so i shiould be ok i would think......... ive never messed much with swapping transmissions, just clutches wich i know can be done without draining the fluid. thanks guys
Old Jan 26, 2011 | 07:24 PM
SoCal4Running's Avatar
Its possible for oil to be in the adapter area. The transmission has a rear output seal that could leak the the transfer case just has a bearing and don't think there's a seal there.
Why not just drain them and consider it your gear oil change for the decade?
Old Jan 26, 2011 | 07:38 PM
weakyota91's Avatar
im actually doing this for my little brother if it were myne i would drain and add new fluid to both tranny and t/c. he doesnt care i dont think. i was just trying to cut corners i guess figured i would get everything in and back together then worry about a fluid change
Old Jan 26, 2011 | 08:47 PM
Ok, well either way if they are full and you pull them apart try to keep them somewhat level. Oil will pour out of the output shaft of the trans if you angle it down.
Liadrin
Apr 25, 2022 02:54 PM
mskalmus
May 28, 2017 07:51 AM
jjrbus
Jul 17, 2015 07:06 AM
Poncho0206
Jul 10, 2015 06:21 PM
madxman21
Jul 9, 2015 10:26 AM
