22RE Head To 22RET
Old Jan 24, 2011 | 04:00 PM
Brad3902's Avatar
22RE Head To 22RET
22RE head to 22RET. Is this even posable.
Old Jan 25, 2011 | 09:38 AM
annoyingrob's Avatar
Sure. You need to move a few exhaust studs around, but beyond that they're almost identical.
Some people say that the volume of the turbo heads is slightly more than the N/A heads (lowering compression), but I've never seen any proof of it. I've had both side by side, and they look the same to me.
Old Jan 25, 2011 | 09:42 AM
xxxtreme22r's Avatar
I might be wrong, but doesn't the turbo head have provisions for the oiling system for the turbo itself? or is that just the block itself?
Old Jan 25, 2011 | 12:05 PM
The oiling for the turbo is all in the block. In fact, it exists in non-turbo blocks as well it's just not drilled and tapped.
For what it's worth, I currently have a turbo head on my non-turbo motor.
Old Jan 25, 2011 | 02:01 PM
Brad3902's Avatar
Hey thanks for the info that's exacly what I needed to hear, I have a friend with a rebuilt head I can get for cheap. I figured I would just put a new one on along with water pump, timing chain, chain guides and along with all the other gaskets since I blew my HG
Old Jan 25, 2011 | 02:12 PM
Brad3902's Avatar
Thank you guys for all the quick responses, I am new to the whole forum and yotatech thing, but u guys rock!! This will be my first attempt at taking apart an engine so I'm a little apprehensive, I'm more of a gear head. I have looked through all the 22re HG swaps on hear is there anything special or different between the 22ret and 22re that I need to know about. Any info would be helpful and thanks again.
Old Jan 28, 2011 | 05:57 PM
tried4x2signN's Avatar
From: Nashville TN. I can help you if you're close BUT NOBODY CAN HELP YOU IF YOU DON'T FILL YOUR LOCATION IN!
I don't have A CLUE what you're attempting to accomplish, but here ya go.
http://www.lcengineering.com/TechNotes/?techid=49
Favorite this link so you can look at it w/o having to start another thread in the future.
IF, you've got a RE you'll be lowering its C/R... IF, you're putting a RE head on a RTE block you'll be bumping it up.
Both heads are the same ex one had a bigger bit mill the combustion chamber out.
Same valve sizes and angles exhaust chambers and all.
88sasturbotoy
Jan 30, 2026 01:57 PM
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
jake_v
Jul 22, 2015 03:17 PM
ryerye13
Jul 14, 2015 08:27 AM
