mystery coolant leak
Old Jul 15, 2009 | 11:57 PM
jmoore9982's Avatar
I have a 95 runner with the v6, auto trans. My problem is that I have a coolant leak somewhere but can not find the leak. If I park the vehicle over night there will somethimes be a small amount of coolant showing on the driveway in the am it is on the right front of the truck and appears to be dripping onto the skid plate before it hits the ground. I have looked all over and can not find the leak and it doesn't always mark it's spot. I am having to put in a quart of coolant about once evey 3-4 weeks. Any suggestions?
Old Jul 16, 2009 | 12:05 AM
Elton's Avatar
bottom of the radio cracked ? bad hose ? drain valve a little loose ?
Old Jul 16, 2009 | 12:11 AM
jmoore9982's Avatar
That's what I thought and have checked all. I suspected the radiator, but can't find a leak
Old Jul 16, 2009 | 12:24 AM
Elton's Avatar
could be a leak cause by pressure
Old Jul 16, 2009 | 02:46 AM
TNRabbit's Avatar
This symptom CAN be (but not necessarily IS) the water pump going out; it will drip from the weep hole under pressure but it's not obvious when it's sitting. Get under there with it running & sit for a spell watching it...
Blamalam
Mar 12, 2022 07:34 AM
SubiKing
Aug 21, 2021 03:57 AM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
