Need Help with noise in my 3.0
Old Jul 16, 2009 | 11:02 AM
bigworm's Avatar
I have a 94 4x4 pickup, and while out hill climbing I noticed a loud tapping. It is coming from the driver side head. i pulled the valve cover and the noise seems to be in time with the front lobe of the cam. I then removed the timimg belt cover and i do not see anything that would be causing this. Looking for any suggestions. thanks
Old Jul 18, 2009 | 10:31 AM
MudHippy's Avatar
So let me get this straight...you removed the valve cover and the thing still ran? That should have caused a massive vacuum leak and caused the engine to be unrunnable. Or did you plug the PCV inlet hole in the intake hose first?
Anyway, have you checked the valve lash for those valves. You could need to adjust one or more of them(if too loose they'll make a tapping sound). Or you could have a worn out valve guide(s) causing some valve tip and/or worn valve lifter(cam follower) rattling around a bit or sticking a little. Or the cam lobe(s) could be worn causing the valve lash to be excessive(again too loose=tapping sound).
Good luck!
jashoeuh
Nov 18, 2024 08:08 AM
coleypull15
Nov 3, 2015 07:41 AM
genuinegemini
Aug 3, 2015 04:56 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
razorman8669
Jul 12, 2015 12:13 PM
