Brake pins.....
Old Jul 13, 2009 | 05:24 PM
a4runnerfreak's Avatar
From: Grew up in S.C.V, So Cal.....now in Hampstead, NC
Brake pins.....
I'm in the middle of installing new front drive axles, bearings, and my Aisin hubs. Already got the driver's side done, and put back 2gether. I've started the passenger side, and noticed that I only had 1 brake pad retainer pin. Can I buy 1 at Vatozone or Napa? Kinda hoping I don't have to go to the stealership.
The pin I'm referring to, goes thru the caliper, and holds the pad in place.
Thanks all
Old Jul 13, 2009 | 05:32 PM
qdude79's Avatar
Saw them at Autozone last time I did a change, though I didn't need 'em at the time. Give them a call.
Old Jul 13, 2009 | 05:39 PM
pntbol11's Avatar
I'm sure you can. I did the same front end work a few months ago. I bought new calipers and they came with new pins. So the should have some. If not a junkyard will.
Old Jul 13, 2009 | 06:07 PM
Yodaforce's Avatar
I actually had some round steel stock laying around (the kind you find at the end of a chain link fence) and presto!.
Old Jul 13, 2009 | 06:26 PM
Matt16's Avatar
You could probably just make one for cheap- they just locate the pads while the calipers aren't squeezing.
BUT... they probably aren't too expensive at the stealership. The part number is 477488. http://www.toyodiy.com/parts/p_U_199...MSEA_4705.html
Old Jul 13, 2009 | 11:04 PM
Thanks for the part number Matt. The only reason I didn't wanna go that route was my nearest stealership is like 75 miles away......
Old Jul 14, 2009 | 03:09 AM
Matt16's Avatar
My new calipers just came with new pins, if you can hold out, send me your address and I'll mail you the old pins.
Old Jul 14, 2009 | 04:12 AM
Byrdman22's Avatar
I Just did my Brakes Last weekend... I needed the same part got all 4 for $13 at advance auto.
Old Jul 14, 2009 | 07:13 AM
qdude79's Avatar
Unless you're good at fabrication, I'd be leary of making my own. What if the pad doesn't slide correctly 'cause the pin isn't straight, or the right diameter (binds up)? I'd take Matt up on his offer. I don't mess with brakes...
Old Jul 14, 2009 | 08:30 AM
PCE91V64x4's Avatar
I got 4 at the dealership and they were only $1-2 each if I remember correctly. My local Advance did not have them.
Old Jul 14, 2009 | 10:13 AM
jasonbrink's Avatar
I just went thorough this too. My local advance didin't have them, nor do they have them available to order. Autozone does carry them, $8:
Part number: H15045
http://www.autozone.com/autozone/cat...entId=cat30058
Jason
1uzRunner
63
Nov 10, 2018 03:58 PM
old87yota
Sep 9, 2015 12:39 PM
fabing455
Sep 7, 2015 08:08 AM
Scatterbrain
Sep 3, 2015 06:46 PM
