HELP!! Truck wont start :(
Old Jul 10, 2009 | 11:30 AM
J's-88's Avatar
SO when I bought this truck i didnt realize the previous owner had crossed the battery cables, so when I installed a new battery i didnt notice he had the RED as Negative and BLACK as possitive
The truck ran great prior to me crossing these wires lol.
There was an 80 amp fuse in the eng. bay blown that I replaced and also a 7.5 amp fuse was blown in the fuse box located at drivers side kick panel area. I have no fuse box cover so i cant tell what it was that was blown there.
I have spark and tried starter fluid and it acts like it wants to start but isnt gettin any gas, I cannot hear the fuel pump running with the key in th ON possition and am sure thats why it isnt starting but my question is: could I have blown any other fuses or relays that would kill power to the fuel pump?? I really dont wanna drop the tank and replace the pump if i dont have to so im asking for your help!!
vehicle is an 88 4runner with 3.0 EFI
Old Jul 10, 2009 | 01:48 PM
yoterr's Avatar
yeah you prolly did, either some relays or poss the ecu crossed bat cables suck
Old Jul 10, 2009 | 01:52 PM
OrRunner's Avatar
If you decide to replace the fuel pump if that is the problem you should not have to drop the tank. under the passenger side of the rear seat ther should be an acess door to the top of the tank. the lid is held on by 3 philips screws. hope this is helpful
Old Jul 10, 2009 | 01:57 PM
yoterr's Avatar
that makes it easy, take a test light to the connector to the fuel pump and see if it lights up when you turn the key on
Old Jul 10, 2009 | 02:08 PM
J's-88's Avatar
ya ill try that , i called dealer and they think its my ECU
Old Jul 13, 2009 | 09:22 AM
J's-88's Avatar
thanks for the help, it turned out to be the ECU, i got one from a wrecking yard for 50 bucks, installed and it started right up
the info regarding the fuel pump was great I had no idea you could access it from there, and that should help in the future.
bigblue82
10
Jul 6, 2015 08:27 AM
Badger62811
Jun 26, 2015 09:26 PM
slider417
Jun 22, 2015 10:18 AM
jmc88runner
Jun 18, 2015 03:39 PM
