dang thing still has the check engine light on
Old Jul 13, 2009 | 02:43 PM
toomster's Avatar
Hello all,
So here is my issue. I have the check engine light on. The codes are reading rich, and lean at the same time. I have set the timing to 5deg tdc. Set idle to 750. Ran sea foam through it. Checked 02 sensor it is reading a constant .6 vts if that means anything. I have tightened everything I can think of. New Plug wires, new plugs, new rotor, new rotor cap. Just re-adjusted the valves. Just re-adjusted the TPS. Just replaced the pcv valve. Still gets bad gas MPG compared to my old 89. Still has the check engine light on. Still for some reason somehow automatically drops the idle down to about 200rpms every time I set the idle to 750. Thoughts.... Anyone????
sonic concepts
Aug 16, 2025 03:13 PM
rbravo1
Jun 29, 2015 01:34 PM
Alex Bessinger
Jun 28, 2015 10:05 AM
94hiluxZE
Jun 22, 2015 10:42 AM
Mutinebullfrog
Jun 18, 2015 01:36 PM
