Wrapping wires with foil for heat protecting?
Old 07-11-2009, 11:56 AM
Tubbyfatty's Avatar
So the group of wires on top of my x member is getting a little hot and kinda burnt from the exhaust pipe. I dont want to go out and buy $20 worth of heat shielding when i just need a 4'' piece.
Should i use some foil to protect the wires from melting? The wires are about 3'' away from the pipe but they are just starting to get cooked.
Old 07-11-2009, 12:59 PM
Nashman00's Avatar
don't be a cheep ass do it right
Old 07-11-2009, 01:07 PM
iamsuperbleeder's Avatar
^lol
well I've never seen tin foil used before for that, lol
personally, I'd use some stuff made for it; just cut some off any junk yard car or something instead of paying $20 for a full roll...
Old 07-11-2009, 01:20 PM
abecedarian's Avatar
a little exhaust wrap around the pipe is an option.... but I don't think I'd use foil. A smooth surface is a much better reflector... or grab a piece of fiberglass insulation from somewhere.
Old 07-11-2009, 02:25 PM
DupermanDave's Avatar
Originally Posted by iamsuperbleeder
^lol
Honestly, I've never seen tin foil AT ALL. As far as I know, everyone used aluminum foil and has used it for a few decades now.
Old 07-11-2009, 02:39 PM
Tubbyfatty's Avatar
Hahaha, I was just throwing out ideas.
Old 07-11-2009, 04:28 PM
I would wrap it in foil and then get some heat shield material for it. that materia is always nice to have in case you want to wire something up
Old 07-11-2009, 04:43 PM
oh jesus, you know what I meant
Old 07-11-2009, 05:27 PM
Fossilized
Staff
dropzone's Avatar
head out to the Tigard U Pull it off 99W. I am sure you can find some 'genuine' automotive stuff out there for less than a buck. They charge very little for the random stuff like insulation.
Old 07-11-2009, 05:29 PM
I did. I like to make the world more difficult though.
Old 07-11-2009, 06:35 PM
taikowaza's Avatar
I really like the thermo-tec line.
I had issues with burning spark plug wires, alternator wire and even starter after I got my thorley headers.
I wrapped everything in thermo-tec and then clamped the tape over each line using a metal clamp. It looks professional and offers excellent thermal protection from radiant heat (they claim it protects from over 90% of heat up to 2000 degrees). Again, this isn't header wrap (that's NOT a good idea) but this is for wrapping anything that will get too hot. You can find this tape cheap if you look around. Good luck
[IMG]
Click for full size [/IMG]
Old 07-11-2009, 08:39 PM
Tubbyfatty's Avatar
Yea i was thinkin about that. Ive only been once and that was a longggg time ago.
What part of the car would i get it off of?
Old 07-11-2009, 08:45 PM
Jay351's Avatar
Any wiring that runs close to the exhaust...
Old 07-11-2009, 08:46 PM
Tubbyfatty's Avatar
haha so basically anywhere? lol.
Old 07-11-2009, 09:11 PM
Jay351's Avatar
Pretty much. Just cruise the junkyard and look for heat insulation in good shape. Most times everything is already taken apart so you can just slide off the insulation
Sleaker
08-26-2020 06:03 AM
the1998sr5
15
07-14-2020 08:35 PM
jasonty
41
12-23-2018 01:00 PM
jjrbus
07-19-2015 02:06 PM
Quick Reply: Wrapping wires with foil for heat protecting?
