Coolant Leak
Old Jul 10, 2009 | 11:26 PM
24Runna's Avatar
Coolant Leak
While changing my oil I was thinking to myself how happy I was that the engine I put in hasn't leaked any fluids.
Oh wait whats that wet spot, oh wait its green..... poop...
It looks like it's coming from the front of the engine, which I assume is the water pump? What are the odds of the coolant coming from the back but seeping along the edges of the of pan to the front?
Weird thing is I haven't lost any noticeable amount of coolant....
Old Jul 10, 2009 | 11:38 PM
Tubbyfatty's Avatar
I wouldnt really worry about it. Just keep a close eye on your fluid levels.
Old Jul 11, 2009 | 12:06 AM
24Runna's Avatar
What would happen if the water pump went out?
Old Jul 11, 2009 | 12:24 AM
space-junk's Avatar
your truck would overheat very quickly...
if the waterpump were gone there would be NOTHING to pump the water through the system...
Old Jul 11, 2009 | 12:28 AM
24Runna's Avatar
Sorry my stupid was on.... haha...
I'll just keep an eye on my fluids, and my gauge...
Old Jul 11, 2009 | 04:47 AM
TNRabbit's Avatar
Actually, 9 times out of 10 the water pump SEAL goes out, dumping out the coolant. It usually starts with seeping that goes on for a while, them BAM~
Old Jul 12, 2009 | 10:54 AM
sh0kk86's Avatar
takes a half hour at most to reseal the water pump. take off the fan and shroud to make life easier as well
Old Jul 12, 2009 | 11:03 AM
Jay351's Avatar
The 22r(e) yes. Its a super simple job, but for the 3vze you gotta tear the front of the motor off.
Remove all belts and accessories, timing cover and such. Might aswell do a timing belt while you're at it...
Old Jul 12, 2009 | 07:44 PM
sh0kk86's Avatar
^good call. i kinda assumed he had a 22re, and didnt even ,look. im an idiot
Old Jul 12, 2009 | 08:57 PM
24Runna's Avatar
How long do I have until its a problem? I've put on 300 miles since my first post and have noticed no coolant lost at all.
Old Jul 13, 2009 | 04:55 AM
GorgeRunner's Avatar
I have a similar leak on my 95 4Runner. Coolant is appearing on the top of the timing belt cover; I figure it's leaking somewhere around the water pump and the belt is blowing out the coolant out the top of the timing belt cover seam.
It was like that most of last winter; but I have a new pump and timing belt in hand and plan to take care of it in the next week or two.
Old Jul 13, 2009 | 05:23 AM
TNRabbit's Avatar
If you have coolant on TOP of your timing belt cover, I'd suspect the lines running to the Throttle Body first....
Old Jul 13, 2009 | 09:01 AM
I was hoping it would be something on top, but I R&Red a bad injector a little while back and replaced all the heater and manifold hoses. No coolant on the intake manifold, only the bolt recesses of the timing cover. I've run the engine looking for the leak and didn't see anything; but after running it for awhile I'll pop the hood and there it is. Not much of a leak; gotta be a bad seal or gasket that leaks only when the engine warms up and runs at highway speeds.
Old Jul 14, 2009 | 08:28 PM
24Runna's Avatar
GorgeRunner, I think mine is the same too. I haven't had time to look between work and college financing stuff, but I will take a more in depth look soon.
Have you noticed any coolant loss?
Old Jul 15, 2009 | 05:26 AM
Just a little bit from time to time. It's got to be a small leak; it doesn't even drip on the ground, just a little on top of the timing cover in the bolt recesses where the wire looms are.
Old Jul 15, 2009 | 06:51 AM
TNRabbit's Avatar
I had a coolant leak one time that gave me a helluva hard time; it was in a small hose & would open up like lips when I revved the engine up, but didn't show otherwise!
Old Jul 15, 2009 | 08:19 AM
The reason I changed all the heater hoses was that there was a small leak in one of those bypass hoses behind the plenum. What a pain in the butt.
Blamalam
Mar 12, 2022 07:34 AM
SubiKing
Aug 21, 2021 03:57 AM
WellsR
12
Jul 31, 2015 03:27 PM
itzmywife's
Jul 25, 2015 04:55 PM
Avenged
Jul 9, 2015 07:55 AM
