Correct idle RPM for 22RE
Old Apr 8, 2006 | 09:10 PM
joshg's Avatar
just purchased a '93 yota 4x4 and am currious about the idle. It seems to be idling at too high of an RPM - it's around 1,200 - 1,400 at idle. Any insight into what the proper idle speed should be?
Thanks much,
Josh
Old Apr 8, 2006 | 09:12 PM
waskillywabbit's Avatar
My 85 and 87 both idle at 1000 rpm...with the AC on, the 87 a tad higher, but not much, maybe 1200 rpms max.
Old Apr 9, 2006 | 11:37 AM
AH64ID's Avatar
Mine is at about 700, but I am going to bump it up a bit. My alternator kicks off at 650rpm, even with a 100amp kit and a smaller pulley...
Old Apr 9, 2006 | 03:45 PM
Elton's Avatar
i have mine at 800rpms
Old Apr 9, 2006 | 05:37 PM
84sr5yoty's Avatar
The manual calls for 750-950 RPM. 750 is a tad rough so I set mine at 800. Anything over 950 and you get problems with a fluctuating idle (usually with the bakes applied) because the computer is trying lower the RPM's and lean out the fuel mixture. Toyota programmed this as "deceleration fuel cut-off." Saves gas and lowers emissions.
Sleaker
Aug 26, 2020 06:03 AM
Alex Bessinger
Aug 31, 2015 09:17 AM
kcaudill
Jul 20, 2015 12:06 PM
kyletbert
Jul 17, 2015 11:39 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
