150K Engine Checkup
Old Apr 5, 2006 | 12:43 AM
91ToyTrck's Avatar
150K Engine Checkup
I am getting ready to change my oil in the truck right around 150K. I'm changing out to Synthetic Oil, but should I change out my plugs, wires, cap, and rotor while I'm there since it's hittin 150K ? I remember when I changed all that on my my '92 it improved the trucks performance. Just felt like it drove better. Also, since I'm switching to synthetic do I need to do anything different when I change my oil or just do it like normal? What's a good brand of spark plug wire? I'm gonna use NGK plugs and just stock cap and rotor.
what do yall think?
Old Apr 5, 2006 | 12:52 AM
wrenchmonster's Avatar
If there is nothing wrong with the plugs, wires, etc. I would see no reason in changing them because of the switch to synthetic oil. If you are doing them as part of your maintainence schedule, that's great. How long has it been since a full tune was done?
The synthetic oil question is a can of worms. My personal opinion for switching is to run an oil compatible with both synthetic and dino, then at the next oil change switch to full synthetic.
Old Apr 5, 2006 | 01:24 AM
91ToyTrck's Avatar
That's the thing about the schedule part is that I don't really know because I just purchased the truck a couple months ago. I do know at 90K the truck had the factory recall about the headgasket done and they replaced a tone of stuff around that area including the timing belt, water pump, and clutch. That's why I was asking about the plugs, wires, and etc.
what is this synthetic / dino combo you are referring ?
Old Apr 5, 2006 | 02:07 AM
bob200587's Avatar
Valvoline Durablend is a syth/conventional mix oil. If I didn't already have a leak I'd proabably switch.
Old Apr 5, 2006 | 08:43 AM
91ToyTrck's Avatar
Alright sounds good. I'll check into that when I head up to Advanced this weekend.
icentropy
Sep 16, 2020 02:47 PM
RaginAsian91
Engine Swaps
Mar 30, 2019 09:17 AM
Sep 4, 2015 09:27 AM
Seattle_Sign_Guy
Jul 12, 2015 12:38 PM
razorman8669
Jul 12, 2015 12:13 PM
