CEL Trouble code...what does this mean?
Old Apr 10, 2006 | 07:20 AM
wheelin4cheap's Avatar
I pulled the trouble codes on my 90 3.0 4runner. It comes out 2 4 3 1 3 2. This is the only code. Anybody know what this means? I can't find anything remotely close to this in the chilton's.
Old Apr 10, 2006 | 08:40 AM
jay-q's Avatar
possibly codes 24, 31, and 32
Old Apr 12, 2006 | 10:34 AM
jammer6's Avatar
CEL (Check Engine Light Codes) OBD1
I have printed out all the codes for the OBD1 and if you read the flashes coming from your check engine light and got the 24 31 32 followed by a pause and then they repeated themselves here is what they mean.
24 - Intake Air Temperature Sensor signal
31 - Air Flow Meter signal (Vacuum Sensor signal)
32 - Air Flow Meter signal
Because you have a swing door MAF sensor I suspect you are dealing with a clogged air filter or a bad sensor (unusal but it could be the problem). I don't know if there is a way to remove it and service it or not.
voiddweller
Oct 2, 2015 07:47 AM
Sam hain
19
Sep 30, 2015 08:25 AM
Matthew Perez
Sep 28, 2015 05:43 PM
charlie_fong
Sep 27, 2015 10:06 PM
Draven023
Sep 26, 2015 12:41 PM
