Rear Antilock light on and off!
Old Apr 1, 2006 | 06:10 PM
JRunner90's Avatar
My rear antilock light comes on almost everytime I drive my runna. What could be the problem bad sensor??
Old Apr 1, 2006 | 08:52 PM
wrenchmonster's Avatar
Probably... check the wiring and pull out and check the sensor. Also, look down the hole at the ring and inspect the teeth. If you have an oscilliscope or even a DVOM you can check the sensor operation.
Most often than not it's a wiring problem. Start the rig and crawl under and wiggle the wiring and I'll bet you'll set the light. Check the plug in portion too to make sure it's not corroded or has dirt in there.
Old Aug 14, 2006 | 06:12 PM
JRunner90's Avatar
Sorry it took so long to reply but the connector for the rear anti-lock sensor should be on the axle right?? Thanks for your help!!
ashersullivan88yota
Jan 18, 2022 05:37 PM
Jun 1, 2021 01:51 PM
BeMiceElf
Oct 10, 2015 09:40 PM
Johntom240
7
Jul 13, 2015 12:18 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
