Front end noise...help, thanks
Old 04-04-2006, 02:42 PM
Swissdrums's Avatar
Hey everyone,
So i know it is difficult explaining noises online, but i am going to do the best i can...
For the past 2 days, my front driver side seems to be making a consistant high pitched buzz/squeal. I know it is not my spindle bushings becuase my hubs are not engaged in the "locked" position. When the noise first started, it would only come about when doing right turns. Now, it is at the point as to where it stays with me untill I do a hard left.
My spindle bushings were on the verge of going, but i havent needed to lock the 4wd in for a while, so i figured this was not a bothersome issue.
It does not seem to be any engine components becuase i was reving the engine and there was nothing. Nor was it my power steering becuase when i turn sitting still, nothing either. It only happens when i am moving.
Again, it is a high pitched consistant squeal/buzz coming from the driver side front. Thanks for all your help. Any information on what to look for would be great. Thanks!
-Mike
Old 04-04-2006, 05:36 PM
Swissdrums's Avatar
After a 5 page essay on an AP Language and Composition Prompt and still nothing?!?!!
Old 04-04-2006, 06:52 PM
AH64ID's Avatar
Well the bearing are turning no matter what position your hubs are in. The only thing that doesn't spin is the CV, which doesnt carry any load.
I would quess that you need to pack your wheel bearings. Probally only started in a turn since the force changed a little. Now they are getting dry. I beleive Toyota reccommends packing them every 12K, mabye its 24k?? I try to do it every 12-18 months.
Old 04-04-2006, 07:19 PM
Swissdrums's Avatar
What do you mean "packing" them? Sorry if thats a dumb question, i assume it means grease/lube?
Thanks for the advice though
Old 04-04-2006, 09:37 PM
AH64ID's Avatar
Yes, you pull them out, and the simple way is to put a ball of grease in your hand and beat the bearing into your hand, like packing a can of chew. Do this until grease is in and around the entire bearing, and then some. This is also a good time to get a hub rebuild kit and go thru everything. Not sure about factory hubs but Warn makes a kit just for that.
Old 04-05-2006, 06:15 AM
Injohneer's Avatar
Packing bearings is like feeding babies. Keep pushing it in until it comes out the other end.
Old 04-05-2006, 10:22 AM
AH64ID's Avatar
Originally Posted by Injohneer
Looks like your feeding your truck creamed carrots
Old 04-05-2006, 10:39 AM
Injohneer's Avatar
oh no, I got the grease and baby food mixed up again...
Old 04-05-2006, 11:31 AM
AH64ID's Avatar
Well, I hope your wife is the one changing the diapers
Old 04-05-2006, 12:20 PM
Swissdrums's Avatar
thanks guys...one question, i have seen that bearing before, is it from the hub or front axel?
Flying91
45
04-11-2024 04:39 PM
jasonty
41
12-23-2018 01:00 PM
09-04-2015 09:27 AM
Daneums
08-20-2015 05:36 AM
88sasturbotoy
08-11-2015 01:56 AM
Quick Reply: Front end noise...help, thanks
