Strange noise?
Old Apr 10, 2006 | 07:40 PM
prerunxj93's Avatar
Strange noise?
i was on the freeway yesterday and all of a sudden i started hearing this loud ticking type noise. which u can only really hear when i apply throttle or force on the engine. i thought it might of been an exhaust leak but im pretty sure its coming from the valvetrain area what do you guys think it might be? What are the valve specs for a cold motor as my motor never even warms up full how far on the temp gauge is it supost to climb becuase it never reaches passed about 1/4 of the guage. im guessing thats a thermostat issue. oh yea this is on a 92 toyota pickup 22re.
Old Apr 11, 2006 | 04:35 AM
maxpower_hd's Avatar
Let it get as hot as it will get before you adjust the valves. The exact procedure is in the manual and it's quite easy. It needs to be up to normal operating temperature. Also check the timing chain guides while the cover is off. The driver's side one breaks on most of the ones I've seen and can also cause the noise you hear.
I wouldn't think that the valve adjsutment would "suddenly" go out though. That is something that I would think would progressively get worse over time.
Old Apr 11, 2006 | 08:54 AM
prerunxj93's Avatar
i pulled the valve cover off and the timing chain guides actually look really good. and the noise gets louder as it warms up. its gotta be the rock arms? not sure what else it could be il see if i can get a sound recording of it
Old Apr 11, 2006 | 06:01 PM
86_runner's Avatar
had one in the shop the other day with tick under the hood that got louder the more it warmed up and we adjusted the valves and found a broken valve spring. So my advice would be to check those too.
Old Apr 11, 2006 | 08:37 PM
prerunxj93's Avatar
well i went and did the adjustment and started it back up and found an exhaust leak. what is that bar on top of the header? the end of it were it mounts to a gasket it leaking.
Old Apr 11, 2006 | 08:42 PM
Elton's Avatar
that bar your talking about is the air injection manifold and the gasket is less than $3 bucks...........also its not easy adjusting the vavles when its hot cuz your going to burn your self thats why most pepole do it cold
Old Apr 11, 2006 | 11:12 PM
prerunxj93's Avatar
yeah, thats why i did them cold lol. i found it tricky though trying to get them the right tightness against the feeler gauge. first time iv ever worked on these motors before as i just purshased this truck . imma pickup up that retarded gasket it somehow like blew out of its position. i wonder if it had anything to do with the motor not heating up all the way which means its been runing rich.
Old Apr 12, 2006 | 06:32 AM
I where a set of mechanics gloves and do it hot. No burns.
Old Apr 14, 2006 | 07:17 AM
prerunxj93's Avatar
wow after replacing the gaskets and starting it up i realize that was not the issue lol. i look at the exhaust header/manifold and it is missing a bolt!! at the end of it. and i can feel aton of air coming through the hole and around it lol. so i do believe that is whats causing the leak? anyone know were i can get a new header bolt. or know of the thread and size of it.
Old Apr 14, 2006 | 12:20 PM
prerunxj93's Avatar
nevermind just ended up getting them from dealer thanks everyone for the help.
Old Jun 26, 2006 | 07:11 PM
Sonofmayhem's Avatar
did it work? Stop the noise? i have the same issue
Old Jun 27, 2006 | 03:56 AM
Flash319's Avatar
Sounds like a head gasket. One cylinder leaking into the one next to it. This has happend 2 times to me between number 3 and 4 cylinders.
Old Jun 27, 2006 | 04:02 AM
SupraSport's Avatar
Adjust your valves hot to do it right
zytra
Jan 24, 2019 03:16 PM
Davebarbier
Nov 3, 2015 03:28 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
JPV
Sep 28, 2015 03:15 PM
