Body Lift = Broken Mounts
Old Mar 28, 2006 | 12:42 PM
M threezy's Avatar
Angry Body Lift = Broken Mounts
Found out my 4runner I just bought has broken mounts due to a body lift. Has anyone experience this horrid thing? haha How should I fix it and renforce that area?
Old Mar 28, 2006 | 12:43 PM
Localmotion's Avatar
what did you use for the body lift???
I have never seen that before...looks dangerous!
Old Mar 28, 2006 | 12:46 PM
M threezy's Avatar
I bought the truck like that. Looks like a 3" metal/aluminum BL. Me not checking it throughly came to find this out. It makes a wreched metal scrapping noise when you turn, I thought it was from the lose spare underneath the truck.
Old Mar 28, 2006 | 10:30 PM
M threezy's Avatar
anyone?
Old Mar 29, 2006 | 12:47 AM
wrenchmonster's Avatar
Ouch. Personally I would just raise the body and weld on a new plate spreading across the broken hole as wide as I could without cutting into the original structure of the vehicle. I would also definately get rid of the hard aluminum and install a proper block. Or abandon the lift all together?
Old Mar 29, 2006 | 01:53 AM
rocket's Avatar
That looks like a perfect candidate for www.4crawler.com
Fisrt off, get rid of the entire BL and replace it with a shorter (1-2") Poly Urethane BL or just get rid of it altogether. Either way you should also replace the original body mount bushings with poly bushings: http://www.4crawler.com/4x4/ForSale/...l#PolyBushings
Like wrenchmonster said... get/cut a plate of metal (as big as possible) that will lay over the broken mount and then drill out a large enough hole for the bolt. Good luck.
Old Feb 15, 2021 | 06:40 AM
Shanethamayne's Avatar
Hey did you ever fix this? I have the same problem, just trying to lay out my options here
Shanethamayne
Feb 18, 2021 08:00 AM
waskillywabbit
43
Jun 13, 2011 08:10 PM
MurphyzRunner
Sep 11, 2008 02:12 PM
ducaria
Mar 8, 2007 04:18 PM
cabbage
12
Mar 21, 2004 07:51 AM
