The mysterious intake side
Old Mar 30, 2006 | 02:24 PM
RustBucket's Avatar
In the three months I've had this truck I have had the right (exhaust) side of the engine compartment torn to pieces and put back as well as the front. However, the intake is calling my name in a sweet sweet voice manifested in intermittent leaks, retard injectors, and an intermittent cylinder.
How difficult is an intake-side rebuild? I would like to replace all those little hoses and put some fresh gaskets on everything. Also, is there some sort of kit I can get that has all the required hoses and gaskets, or should I just buy them separately?
Old Mar 30, 2006 | 02:57 PM
seaflea's Avatar
You can get the intake gasket set from any decent autoparts store. But the hoses you may have to go to the dealer, OR take them up to the parts store and see if they have the same sizes.
You may as well order the injector seals and o-rings while you are at it.
I have had mine apart a few times. The difficulty comes in when sone of the bolts are frozen or hard to get to.
Old Mar 30, 2006 | 04:33 PM
RustBucket's Avatar
Okay, thanks. All the bolts I have touched on this truck have worked fantastically, due to a fairly recent rebuild and zero rust, so should I expect this project to be pretty easy? (I also have a factory repair manual)
Old Mar 30, 2006 | 04:56 PM
seaflea's Avatar
Yeah, just pay attention to the hoses and where they go.
I normally pull the plenum apart to make the lower part more accessible. You can also get to the injectors this way. Careful when you take loose the fuel line banjo bolt, there is a washer there that needs to be kept. It is really easy to lose.
Old Mar 30, 2006 | 08:29 PM
kyle_22r's Avatar
it'll usually take 1/2 hour to get to the lower plenum if you're careful. hardest part about removing the lower half is getting all the junk out of the way, in fact, the wiring harness runs through the middle of it and i think you have to disconnect a bunch of things. i was able to get a new gasket in mine without removing the manifold from the engine bay, though.
Old Mar 31, 2006 | 04:47 AM
RustBucket's Avatar
Okay, thanks for the tips, guys. I'll probably want to just take everything apart, especially since I want to keep this truck for a long time, so I might as well get accustomed to all its "guts"
Old Mar 31, 2006 | 05:25 PM
84sr5yoty's Avatar
If you're going to redo the intake (I did mine a few months ago) REPLACE THE FUEL FILTER. You'll understand why when you get there. Also, take time the clean the throttle body (and adjust the TPS), plenum, and EGR plumbing. If you have time, send out your injectors to have them ultra-sonically cleaned. I sent mine out and it made a night and day difference. The job is really easy, just time consuming.
Doug4320
Mar 24, 2018 10:11 PM
steve miller
Oct 10, 2015 01:40 AM
RaginAsian91
All Other Toyota Swaps
Aug 23, 2015 10:27 AM
whereAreMyPants
Jul 22, 2015 03:32 AM
87blyota
Jul 10, 2015 04:31 AM
