why oh why won't it start?!
Old Aug 18, 2011 | 01:27 PM
cootees's Avatar
ok, guys.
90 runner 3.0. It was having intermittent starting problems. Now however I just get the dreadful *click.*
It has a new yellow top, new wire from battery to fuse box. I pulled the started and had it tested at advance, tested good.. even grounded the starter directly from the battery. Just put in a new ignition switch. At first try it cranked but now it's back to doing nothing.
Any advice?
Old Aug 18, 2011 | 02:35 PM
stepside trd's Avatar
Have you tried testing/replacing your starter relay??
Old Aug 18, 2011 | 04:11 PM
cootees's Avatar
Overlooked that one. I'll give it a try.
Old Aug 18, 2011 | 04:52 PM
TNRabbit's Avatar
I would consider replacing the starter contacts as well.
Old Aug 18, 2011 | 05:01 PM
KenC's Avatar
i have a similar issue,autozone starter and every once in a while it just clicks and if i lightly tap on the starter with a hammer then it works probably something to do with solenoid.im not saying that is your problem but something to try
Old Aug 18, 2011 | 05:28 PM
jakeasinsnake's Avatar
Have you tried new battery cables? Helped get rid of both the "click" and autozone starter returns.
Old Aug 18, 2011 | 06:54 PM
vasinvictor's Avatar
Remove and clean those terminals with a good terminal brush (or pocket knife). If they are the slightest bit loose, they'll build up acid fast. I know you said you have new cables, but dirty terminals always cause my truck to "click" rather than start.
Old Nov 13, 2011 | 12:51 PM
cootees's Avatar
Still not getting anything. Changed the relay and nothing. I can jump the starter and it turns over. Any other suggestions. Cables are clean. Terminals are clean.
Old Nov 14, 2011 | 05:41 PM
92dlxman's Avatar
ummm isnt the yellow top a deep cycle? dont know much about batteries but wouldnt a red top be better for starting, yellow top for long periods of low-amp draw
Old Nov 15, 2011 | 09:11 AM
takeitoutgetitdirty's Avatar
I agree with TNRabbit, I had the same issue with my starter. Pulled it, took it apart and on of the contacts was completely wore out. If you look on here or on marlins web site there is good info about it. It is also very simple to do, took me about 15 mins once I got the starter out.
Old Nov 16, 2011 | 12:38 PM
gsharp's Avatar
Get one of these..
http://www.summitracing.com/parts/PRF-30202/
I was getting just the click sound after a new starter installed by my mechanic. I added this relay and I have not had a problem since.
Old Nov 16, 2011 | 12:41 PM
gsharp's Avatar
double posted somehow..
Old Nov 16, 2011 | 12:46 PM
oriana'smygirl's Avatar
Not sure but I know I had almost the same issue with my 91 pick up and it was the mass air flow sensor found it by luck the plug in was broken and came loose. I changed all the stuff that you had and that was all it was. Worth a shot
Old Nov 16, 2011 | 01:21 PM
mldave's Avatar
Or you can try this http://www.pirate4x4.com/forum/showt...starter+clicks
Old Jan 16, 2012 | 02:58 PM
cootees's Avatar
I did some rewiring and made some progress. It's clicking but I do not think it is the starter that is clicking. Sounds more like it is coming from the fuse box under the hood. I know there is a fusible link in there for the alternator. If that link goes bad would that prevent the starter from kicking?
sandyota
Feb 4, 2021 11:16 AM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
karbin
Jul 5, 2015 11:37 PM
