22r Fuel Issues
Old Aug 24, 2011 | 07:19 PM
Z's Confederate Toy's Avatar
22r Fuel Issues
I have replaced my fuel filter and fuel pump and I still have no idea what the dealio is. I can get the truck started just fine it idles good but after drivin like 40 feet it just cuts out like its outta gas. When I look at the fuel level glass there isnt more than a drip of gas in there. Anyone have an idea what might be causin this. I have researched and havnt found anything like this.
Old Aug 24, 2011 | 07:31 PM
Broknbonz's Avatar
is there a vacuum on the fuel tank when you remove the fuel cap when this happens ? had an old dirt bike do the same thing and it was the vented fuel cap not doing its job.
Old Aug 24, 2011 | 07:33 PM
You mean the pssshhhh sound when you release the cap? If so, no. I already checked that.
Old Aug 24, 2011 | 07:38 PM
xxxtreme22r's Avatar
gonna keep my responses in this thread instead of your build thread.
Old Aug 24, 2011 | 07:40 PM
Schweet
Old Aug 24, 2011 | 07:52 PM
I think I may have gotten it. I took an air blower a blew out the lines just to rule that out and it immediately brought the gas into the sight glass.
Old Aug 24, 2011 | 07:54 PM
Broknbonz's Avatar
sight glass ?
in the carb or an inline filter ?
Old Aug 24, 2011 | 07:55 PM
Originally Posted by Broknbonz
sight glass ?
On the carb. That fuel line window on the front of the carb right under the air cleaner
Old Aug 24, 2011 | 08:00 PM
Broknbonz's Avatar
ok, if it happens again I would be looking at the float and/or float adjustment.
also, when it stalls again remove the fuel line at the carb and verify fuel pressure when cranking. (just at thought)
Old Aug 24, 2011 | 08:02 PM
might wanna put a new line on it, I've seen that before as well where the inner part of the hose is broken and flapping around in there. Hard to tell from the outside. Always forget to mention that.
Old Aug 24, 2011 | 08:04 PM
That could definitly be the problem. They are most likely the original lines from 87. So they could be be bad on the inside.
Old Aug 24, 2011 | 08:36 PM
99.5% sure that I got it fixed. I just took it for a few laps around the neighborhood and not a single stutter. I appreciate you help guys. I will post back to this thread if I have any other problems
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Tyler Cunningham
Jul 11, 2015 10:18 AM
smiley52
Jul 11, 2015 05:16 AM
nick b
Jul 11, 2015 04:38 AM
